Philips ToUcam PRO II vs Logitech Quickcam Pro 4000
G
Guest
Guest
Archived from groups: alt.comp.periphs.webcam (More info?)
FYI,
This is a short report on the differences between Philips ToUcam PRO
II and a Logitech Quickcam Pro 4000 (i wanted to buy one of them).
Mechanical build: Quickcam (QC) is clearly leading over the ToUcam
(TC). The TC has a very akward and feeble lens focusing mechanism.
while the QC has a nice internal focus mechanism. Also the TC has an
even more feeble base than the TC has, but the TC has an extra mini
tripod to compensate. However this tripod attaches *not* to the body
of the TC but to the base which is folded back. It's mechanical
unstable.
Drivers: The drivers (both updated from respective websites) have
more or less the same options, however the QC has face tracking wich i
did not test. Both drivers proved reasonable stable on an XP system.
The TC driver was clearly better in adapting to different light
conditions, espcially low light conditions.
Picture Quality: Sharpness and overall picture quality was more or
less alike. There where clear differences in color interpretation,
but i cannot asses which one was better. The QC needed less lens
adjusting whit short focus distance.
Low light: An enormous advantage for the TC. TC is *much* more
sentive and keeps detailed pictures with (very) low light conditions.
Also the driver adjusts very good, so no fiddling with settings is
needed. At the tested light levels the QC produces either no image or
mainly noise.
Despite the mechanical disadvantage, for me the clear winner was the
ToUcam.
Hi Slonk,
Did you perhaps try the QuickCam driver on the ToUcam Camera ?
Asking because wifiRouter(compex) here has usb cam/print servers. They
have an approved cam list consisting of several cams mainly from the
Logitech line. The ToUcam pro which I think I would prefer for the low
light handling you and others have mentioned is what I think would work best
for a trial here. Plan on ordering some cam here shortly to experiment
with, be nice to know if ToUcam would function on same driver.
(ps; appears they will shortly have a usb Webcam/Print Server adapter...
spotted in 'wifi' section)
"Slonk" <slonk.nospamp@mapson.xs4all.nl> wrote in message
news:l6l870h14aj4oljtv0ac0sc13bflma8ruf@4ax.com...
> FYI,
> conditions, espcially low light conditions. ...
................., for me the clear winner was the ToUcam.
On Thu, 08 Apr 2004 02:01:30 GMT, in alt.comp.periphs.webcam you
wrote:
>Hi Slonk,
Have no idea how to switch the drivers! If you are able to point me
out *specific* instructions under XP, i'm willing to give it a try,
however the QuickCam returns to its shop next saturday, so be quick...
most or at least some of the Messenger type programs that do video that I've
used have Tools or Settings that allow you to select which driver or cam,
provided both drivers are installed.
"Slonk" <slonk.nospam@mapson.xs4all.nl> wrote in message
news:v5u970drcv9sgnbr3r3f99qsbp6cirortp@4ax.com...
> wrote:
> >Hi Slonk,
