Phone wifi slower than PC
  • Thread starter Thread starter Guest
  • Start date Start date
If you mean SMS messages, those shouldn't be affected by WiFi at all.
I'm not sure that this is a...
See, that's the problem. On my desktop, the wifi runs fast but on my iphone, youtube videos buffer and some of the apps stop working and doesn't update due to weak internet. I get delayed text messages and emails.
I should also clarify, my modem is in my room and it's still slow when I use my iphone.
And about the list, I wasn't really sure what I was looking at. I thought it would tell me what my problems are but would it?
On your pc you have 70.4 and on your phone you have 69.89, is basically the same speed. Of course as you get further away from the router you get weaker signal and as a result slower speed, all depends of the wall density and the material but usually a wifi doesnt go well after 2 walls. Put your router somewhere in the center of the hosue or put some access points in different places in teh house.
The test was done right next to the router. The router is in my room and my phone is getting laggy wifi.
I'm not sure that this is a WiFi issue.
I literally wrote that I had major differences in wifi between my phone and desktop lmao wtf.
I'll say it again, my message apps would take up to 5mins to update. This happens in FB chat, Kakao, LINE, and the normal iphone messaging system. Youtube vids would sometimes not even load unless I close the app and reopen it. It wasn't like this before which is why I came here to ask questions. And it's not just my phone, my grandma's android is also affected.
