I keep getting this issue when I try to run Phpmyadmin from my localhost.
Here are my httpd.conf settings:
PhpInfo
Software/Hardware
I appreciate any help you can give me. Not sure what steps to take.
Code:
Fatal error: Uncaught Error: Call to undefined function mb_detect_encoding()
in C:\Apache24\htdocs\phpmyadmin\libraries\php-gettext\gettext.inc:177 Stack
trace: #0 C:\Apache24\htdocs\phpmyadmin\libraries\php-
gettext\gettext.inc(282): _en code('The %s extensio...') #1
C:\Apache24\htdocs\phpmyadmin\libraries\php-gettext\gettext.inc(289): _
gettext('The %s extensio...') #2
C:\Apache24\htdocs\phpmyadmin\libraries\core.lib.php(306): __('The %s
extensio...') #3 C:\Apache24\htdocs\phpmyadmin\libraries\core.lib.php(961):
PMA_warnMissingExtension('mbstring', true) #4
C:\Apache24\htdocs\phpmyadmin\libraries\common.inc.php(102):
PMA_checkExtensions() #5 C:\Apache24\htdocs\phpmyadmin\index.php(13):
require_once('C:\\Apache24\\htd...') #6 {main} thrown in
C:\Apache24\htdocs\phpmyadmin\libraries\php-gettext\gettext.inc on line 177
I have repeatedly gone through and tried all of the suggestions that I can find regarding this issue and have yet to figure it out. I have tried various "/" "\" suggestions with no luck.
Code:
ServerRoot "c:/Apache24"
Code:
</IfModule>
LoadModule php7_module "c:/php/php7apache2_4.dll"
AddHandler application/x-httpd-php .php
PHPIniDir "c:\PHP"
Here are my php.ini settings:
; Directory in which the loadable extensions (modules) reside.
; [url=http://php.net/extension-dir]http://php.net/extension-dir[/url]
extension_dir = "C:/PHP/ext"
; On windows:
Code:
;extension=php_bz2.dll
;extension=php_curl.dll
;extension=php_fileinfo.dll
;extension=php_ftp.dll
extension=php_gd2.dll
extension=php_gettext.dll
;extension=php_gmp.dll
;extension=php_intl.dll
;extension=php_imap.dll
;extension=php_interbase.dll
;extension=php_ldap.dll
extension=php_mbstring.dll
extension=php_exif.dll ; Must be after mbstring as it depends on it
extension=php_mysqli.dll
;extension=php_oci8_12c.dll ; Use with Oracle Database 12c Instant Client
;extension=php_openssl.dll
;extension=php_pdo_firebird.dll
;extension=php_pdo_mysql.dll
;extension=php_pdo_oci.dll
;extension=php_pdo_odbc.dll
;extension=php_pdo_pgsql.dll
;extension=php_pdo_sqlite.dll
;extension=php_pgsql.dll
;extension=php_shmop.dll
PhpInfo
Code:
PHP Version 7.0.13
System Windows NT SERVER 6.3 build 9600 (Windows Server 2012 R2
Standard Edition) AMD64
Build Date Nov 8 2016 13:28:54
Compiler MSVC14 (Visual C++ 2015)
Architecture x64
Configure Command cscript /nologo configure.js "--enable-snapshot-build"
"--enable-debug-pack" "--with-pdo-oci=c:\php-
sdk\oracle\x64\instantclient_12_1\sdk,shared" "--with-oci8-12c=c:\php-
sdk\oracle\x64\instantclient_12_1\sdk,shared" "--enable-object-out-
dir=../obj/" "--enable-com-dotnet=shared" "--with-mcrypt=static" "--
without-analyzer" "--with-pgo"
Server API Apache 2.0 Handler
Virtual Directory Support enabled
Configuration File (php.ini) Path C:\Windows
Loaded Configuration File (none)
Scan this dir for additional .ini files (none)
Additional .ini files parsed (none)
PHP API 20151012
PHP Extension 20151012
Zend Extension 320151012
Zend Extension Build API320151012,TS,VC14
PHP Extension Build API20151012,TS,VC14
Debug Build no
Thread Safety enabled
Zend Signal Handling disabled
Zend Memory Manager enabled
Zend Multibyte Support disabled
IPv6 Support enabled
DTrace Support disabled
Registered PHP Streams php, file, glob, data, http, ftp, zip,
compress.zlib, phar
Registered Stream Socket Transports tcp, udp
Registered Stream Filters convert.iconv.*, mcrypt.*, mdecrypt.*,
string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*,
consumed, dechunk, zlib.*
Software/Hardware
Code:
- Windows Server 2016R2
- PHP 7.0.13
- Phpmyadmin (C:\Apache24\htdocs\phpmyadmin)
- Apache 2.4
- MySQL 5.7.1
