Known for Resin, Phrozen’s first FDM printer is gunning for Bambu Lab
Phrozen Breaks the Ice with Four Color 3D Printer : Read more
Can anyone explain to me why 4 spools the default and not 5 spools for the 'color support'? Asking as doing a CYMK print, that is not a lithophane, it seems like a support material like PVA would make a great 5th spool, so you could print complicated full color designs and have rinse away supports for the finer details.Known for Resin, Phrozen’s first FDM printer is gunning for Bambu Lab
There is no particular reason for using only 4 spools. However most multi material systems struggle with PVA, for example the Bambu Lab AMS isn't compatible with PVA. PVA and other soluble supports are best used with multi toolheads printers.Can anyone explain to me why 4 spools the default and not 5 spools for the 'color support'? Asking as doing a CYMK print, that is not a lithophane, it seems like a support material like PVA would make a great 5th spool, so you could print complicated full color designs and have rinse away supports for the finer details.
Also, physical size.Can anyone explain to me why 4 spools the default and not 5 spools for the 'color support'? Asking as doing a CYMK print, that is not a lithophane, it seems like a support material like PVA would make a great 5th spool, so you could print complicated full color designs and have rinse away supports for the finer details.
