BenK1010,
Motherboard > I had chosen the Supermicro motherboard on the basis that in several cases it placed very high in Passmark benchmark baselines using 2X Xeon 2687w, although the highest rated Xeon 2687w system was an HP. I checked Passmark and other motherboard that did very well included the ASUS Z9PE-D8 WS Dual LGA 2011 Intel C602 SATA 6Gb/s USB 3.0 SSI EEB Intel Motherboard ( $580). However, this board supports only up to 64GB - but that also says in the small print, "supports up to 135W". I like Tyan boards, and they support more RAM, but they also had a 135W per CPU limitation. Still, all the above boards are shown in Passmark baselines as top performers with a pair of 2687's, so a number of users are ignoring the specifications.
I found what I think are three strong possibilities >
1> INTEL S2600COESSI EEB Server Motherboard Dual LGA 2011 DDR3 1600 ($550-$620). (Supports up to 512GB DDR3 ECC UDIMM/LV)
i.
http://www.intel.com/content/www/us/en/motherboards/server-motherboards/server-board-s2600co.html
ii.
http://ark.intel.com/products/63157
iii. Compatible Memory validation>
http://www.intel.com/content/www/us/en/platform-memory/ddr3-udimm-ecc-e5-family-memory-list.html
iv. Review 2012 >
http://www.pugetsystems.com/labs/articles/Product-Review-Intel-S2600COE-144
Intel S2600COE > 16 DIMM/ ECC up to 1600 up to 512GB, 84 PCIe lanes > 4X PCI Express 3.0 x16, 1 XPCI Express x8, 1 x PCIe x8 Gen 3 1X PCI Express x4. 1 x PCIe x4 Gen 2 that would accommodate a a GPU plus Tesla or Xeon Phi coprocessors and there will also be room for something like an LSI Logic RAID controller and/or RevoDrives. 10 SATA ports, LSI RAID support, 4 Ethernet /LAN > every conceivable technology for everything- very complete specifications. This has among the widest maximum memory bandwidths I've ever seen- 102GB/s which is perfect as 2X Xeon E5-2687w has 2X 51GB/s. A dual Xeon X5680 system would have a maximum bandwidth of 64 GB/s (2X 32GB/s). That's of course the great feature of dual CPU's- it creates so many more PCIe lanes and memory controllers. Above is a link to the compatible memory validation for that platform, but these are from 2012 and mysteriously no larger than 8GB modules. Some more research needs to be done to find by brand and model the specific RAM tested on the Intel S2600COE. If you think this board is a good choice, I can have a look at memory. Also, Intel boards have just fantastic build quality.
The review linked above is very informative and notes that this board- and several others I've looked at, have non-standard mounting holes. That review also mentions that this board is more server oriented than workstation and suggests instead using the ASUS Z9PE-D8 WS- which specifies CPU's up to 135W,...
I'm not certain- they don't identify the components used, but I had a look at the Colfax workstation solutions and S2600COE may well be the board they're using. The Colfax site has very good information on the SOTA of Xeon Phi, and while more broadly applicable than I thought, it appears to be oriented towards sophisticated custom code applications, whereas CUDA coprocessing is oriented towards mainstream applications that can use it. This is an argument for Xeon Phi for your use.
2> SUPERMICRO MBD-X9DAi-O Extended ATX Server Motherboard Dual LGA 2011 DDR3 > $490
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182260
http://www.supermicro.com/products/motherboard/xeon/c600/x9dai.cfm
16GB ECC registered 1600 compatible memory >
http://www.supermicro.com/support/resources/memory/display.cfm?sz=16.0&mspd=1.6&mtyp=44&id=8939EE74FDFB9E5DB353166AAAE42C35&prid=82361&type=DDR3&ecc=1®=1&fbd=0
A 16GB Samsung module from the compatible list >
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147183&Tpk=Samsung%20M393B2G70BH0-CK0&IsVirtualParent=1 ($180 each X4= $770 for 64GB, 8X= $1,440 for 128GB)
This board also uses the Intel C602 chipset, supports 150w CPU's and has 16 slots / 512GB RAM, and has 3x PCI-E 3.0 x16 slots, 2x PCI-E 3.0 x8 slots, 1x PCI-E 3.0 x4 (in x8) slot*** . This board does seems to have very good features and produces very good ratings on Passmark and the build quality is very good, though I think not quite Intel standard.
***[ The Intel S2600COE has
4X PCI-E 3.0 x16 slots which may be useful in the event multiple Xeon Phi coprocessors are added. I feel that a RAID controller is probably called for, so a future configuration could be > Slot 1 = Quadro GPU, S2= Revodrive 3 X2, S3=LSI Logic or similar RAID controller, S4= Xeon Phi Coprocessor. Of course, if a Revodrive or other PCIe drive, I call these "direct injection" drives, is not used, then there could be 2X Xeon Phi (about $10,500).]
3> ASUS Z9PE-D16 SSI EEB Server Motherboard Dual LGA 2011 DDR3 1600 > $480
http://www.asus.com/Commercial_Servers_Workstations/Z9PED16/#specifications
memory >
http://dlcdnet.asus.com/pub/ASUS/mb/Socket2011/Z9PE-D16/Manual/Z9PE-D16_Series_Memory_AVL_20130610.pdf
Intel C602-A PCH, 16 DIMM, supporting 512GB ECC 1600, Total Slots : 6 > PCI-E x16 3.0 with Slot 5 running at x8 if Slot 6 is occupied, and Slot 6 is MIO
This appears to be another very good choice and has even better flexibility in terms of the number of PCIe x16 slots.
Compatible memory for the ASUS Z9PE-D16 > SAMSUNG- 16GB (1X16GB) 1600MHZ PC3-12800 CL11 DUAL RANK ECC REGISTERED DDR3 SDRAM DIMM GENUINE SAMSUNG SERVER MEMORY (M393B2G70BH0-CK0) > 128GB= $1,160 ($145 each, Server Direct)
GPU> The S2600COE has onboard graphics but that must share and therefore divert system RAM. I think it's worthwhile to have a good graphics card on hand that could handle high resolution graphs, waveforms, visualization models, and animations. As you mention the geometries encountered are quite simple, for most work it would seem the Quadro K600 would be sufficient. Autodesk certifies the K600 for both Maya and Inventor 2013 which has extensive simulation capabilities. With single and double precision, error correcting RAM, and error correcting VRAM in the GPU, this system will be capable of high accuracy 3D models of particle phenomena like smoke, cosmic dust, comet, asteroid trajectory, extra-solar planetary gravitational perturbation, or galactic evolutionary models. Or structures > crystalline, cellular, vector phenomena, metallurgical, 3D particle annihilation models / vector diagrams. As rendering is CPU-based, this system would be extremely rendering capable. The potential capabilities and expansion of future uses would be significantly enhanced by using, optionally, a Quadro K2000 (2GB) $420, which has much better 3D modeling performance.
The Xeon X5680 > I'm surprised also that the X5680 (released Q1, 2010) can be still so costly- they were originally $1,660, but it does stand out as one of the still very desirable Xeons as it is 6-core and among the higher Xeon clock speeds. If I were building a system for myself today (industrial design), I would probably use a single Xeon E5-1650 (6- core, 3.2 /3.8GHz, about $600), but if it were a dual CPU, I would use the X5680.
"Physics and scientific computing workstation build" > Preliminary Concept 2 >
BambiBoom CalcuCannon Simumathematica Supermodeler II™?™©®©$_ REV 7.4.13
The following configuration was done in consideration of the best cost /performance basis suitable for high calculation density requirements > Mathematical, Astrophysical, vector analysis, particle, fluid, gas flow, and thermal simulation, statistical analysis, molecular biology, static and dynamic structural, 2D/ 3D CAD modeling, graphic design, rendering, architecture, industrial design, financial analysis. >
1. (2) Intel Xeon E5-2687W Sandy Bridge-EP 3.1GHz (3.8GHz Turbo Boost) 20MB L3 Cache LGA 2011 150W 8-Core Server Processor > $3,868. ($1,934 each) On the Passmark CPU benchmark chart, this processor is the No.2 rated, score = 21491. In the top 100 systems on Passmark Performance test, this CPU is used in the 6th highest performing system.
2. (2) Noctua NH-U12S 120x120x25 ( NF-F12 PWM) SSO2-Bearing ( Self-stabilizing oil-pressure bearing ) CPU Cooler > $140 ($70 each)
3. INTEL S2600COESSI EEB Server Motherboard Dual LGA 2011 DDR3 1600 > $580 (Newegg). (Supports up to 512GB DDR3 ECC UDIMM/LV) (see links above for information)
3A. ASUS Z9PE-D16 SSI EEB Server Motherboard Dual LGA 2011 DDR3 1600 > $480 (See links above for information)
4. 128GB (8 X 16GB) DDR3- 1600 ECC RAM for Intel S2600COESSI EEB > About $1,200 (compatibility to be researched)
4A. 128GB (8 X 16GB) SAMSUNG M393B2G70BH0-CK0 1X 16GB for ASUS Z9PE-D16 > 128GB= $1,160 ($145 each, Server Direct)
5. NVIDIA Quadro K600 (with Intel S2600COESSI EEB) VCQK600-PB 1GB GDDR3 PCI Express 2.0 x16 Low Profile Workstation Video Card >$160
5B. NVIDIA Quadro K2000 Video Card (used with ASUS Z9PE-D16 option)- 2GB GDDR5, PCI-Express 2.0 (x16), 1x Dual-Link DVI-I, 2x DisplayPort, DirectX 11, Single-Link, Fan, (VCQK2000-PB) $420.
6. Western Digital WD Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive $90 (Operating System (s) and Applications) While an SSD would load the OS and applications noticeably faster, and large file transfers would be faster, the general experiential qualities of using a 6GB/s mech'l drive should not be a problem.
7. (3) Western Digital WD Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive - OEM $480 ($160 each) (RAID 5) (Active files, backup, system image)
8. SeaSonic X-1250 1250W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply > $254.99
9. LIAN LI PC-A75 Black Aluminum ATX Full Tower Computer Case $182
10. ASUS DVD Burner 24X DVDDRW-24B3ST/BLK/G/AS $28.
_______________________________
TOTAL = Configuration A > Intel S2600COE / Quadro K600 about > $6,975 (depending on RAM cost) OR Intel S2600COE / Quadro K2000 about > $7,335 (depending on RAM cost) OR Configuration B with ASUS Z9PE-D16/ Quadro K2000 > about $7,103
Given your comments, these are the best cost/performance solutions within /close to the budget.
Notes to the above Specification >
A. If it's not proprietary, it would help to have a quite specific description of a typical task for this system so as to make certain it can be optimized.
B. A DVD-R drive is added if only to load OS, network software, and programs, and make spot backup and transfer disks.
C. If the ASUS Z9PE-D16 is determined to have no disadvantages, it's slightly lower cost and allowing the budget overrun to about $7,103 will present a much enhanced 3D capability, that I would recommend for future expansion of use of this system.
D. If the budget allows, I would rather use for the system enclosure > LIAN LI PC-D8000 Black Aluminum ATX Full Tower Computer Case $331.99 (= + $150) >
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112390&Tpk=LIAN%20LI%20PC-D8000&IsVirtualParent=1
> as it provides excellent working space, air flow, and drive expansion possibilities. As well, again if there's a budget for it, I would upgrade the power supply to a server quality and possibly have redundant supplies, which that case would accommodate.
E. A small detail, but this system would benefit from a temperature monitor, fan control panel. Perhaps >
NZXT Sentry-2 5.25" Touch Screen Fan Controller $28.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005
F. Additional case and dedicated RAM cooling fans should be considered.
_____________________________________
I couldn't resist considering whether it's possible to derive a co-processing configuration close to the $7,000 budget. In this instance, a Xeon Phi was out of the question as each module is $5,000. However, it is possible with a Tesla K20>
BambiBoom CalcuCannon Simumathematica SuperTesloidica III™?™©®©$ 7.5.13
1. Xeon E5-1650 6-core 3.2 /3.8GHz, 12MB cache, LGA 2011 $600
2. Noctua NH-U12S 120x120x25 ( NF-F12 PWM) SSO2-Bearing ( Self-stabilizing oil-pressure bearing ) CPU Cooler > $70
3. ASUS P9X79-E WS LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 SSI CEB Intel Motherboard $499.99
4. 64 GB SAMSUNG 8GB 240-Pin DDR3 SDRAM DDR3 1600 ECC Registered Server Memory Model M393B1K70DH0-CK008/Q8/E8 $719.92 ($89.99 ea)
5. NVIDIA TESLA K20 (900-22081-2221-000) GK110 5GB GDDR5 PCI Express 2.0 x16 SLI Supported Workstation Video Card $3,499.99
6. NVIDIA Quadro K2000 VCQK2000-PB 2GB GDDR5 PCI Express 2.0 x16 Workstation Video Card $430.
7. Western Digital WD Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive $89.99 (Operating system / Applications)
8. (2) Western Digital WD Black WD2002FAEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive > $318. ($159.99 each)
9. SeaSonic X-1250 1250W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready $254.99
10. LIAN LI PC-D8000 Black Aluminum ATX Full Tower Computer Case
Item #: N82E16811112390 $331
Total = about $6,900.
This is a very unrefined concept, and I can't predict the results, but at least a multi-GPU coprocessor configuration is possible at reasonable cost. This also opens the question as to whether double precision calculation density is higher when the CPU has fewer cores, but at a higher speed, and then running in parallel with 2,496 CUDA cores at about 700MHz. As massively parallel Tesla K20X's form the processing power of the Oak Ridge Titan, they must be doing something right!
From Newegg >
>""TPeak double precision floating point performance (board): 1.17 teraflops
Peak single precision floating point performance (board): 3.52 teraflops
Memory bandwidth for board (ECC off): 208 GBytes/sec
[This is almost double the 2X Xeon 2687W's]
CFD, CAE, financial computing, computational chemistry and physics, data analytics, satellite imaging, weather modeling
SMX, Dynamic Parallelism, Hyper-Q.
Designed to be the performance leader in double precision applications and the broader supercomputing market,the Tesla K20 and GPU Accelerators deliver 10x the performance of a single CPU2.
Tesla K20 feature a single GK110 Kepler GPU that includes the Dynamic Parallelism and Hyper-Q features.
With more than one teraflop peak double precision performance, these GPU accelerators are ideal for the most aggressive high-performance computing workloads including climate and weather modeling, CFD, CAE, computational physics, biochemistry simulations, and computational finance."" <
I think this new realm of the Personal Supercomputer deserves some study- it writes a very different performance equation.
______________________________________________________
Bizarre Conjectural System Alternative 1 > As I'm not completely certain the tasks that will be assigned to the proposed system, I had a thought that could possibly yield greater total computing power within the budget- that is, in place of 16 cores / 32 Threads @ 3.1 / 3.8 GHz, there would be 24 cores /48 threads running at 3.33 GHz. For $1,400-$1,700 you can buy a used Dell Precision T7500 with one X5680, a reasonable one generation obsolete Quadro and at least 16GB of RAM/ With careful shopping add a second used X5680 for about $900 ($700 CPU, $200 CPU/ memory / fan riser) and new SSD and SAS drives. With a dual CPU, a Precision T7500 can accommodate 192GB DDR-3 1333 ECC RAM. So, for your $7,000 you could have 2 such systems with a Quadro 4000 and 64GB RAM each. Comparatively, the E5-2687w is ranked No. 2 , scoring 21521, and the 2X Xeon X5680 rated 14, scored 14151 for a total CPU power of 28302 , i.e. the 2X dual X5680 systems would present a capability of 131% of the single dual E5-2687w. The key is whether two machines are useful in separate, coordinated functions- that is, can work independently parallel on different aspects of a single problem that may be synchronized. This craziness arises from the description of COMSOL Multiphysics and recent supercomputers using modular CPU/ GPU coprocessing , like the Oak Ridge "Titan". If those independent modules (18,600+ AMD FX 8350 8-core CPU's each controlling a Tesla K20X, configured in rack-mount chassis like servers) can be linked in parallel there must be a sufficiently wide bandwidth connection existing.
Bizarre Conjectural System Alternative 2 > If the above idea has any validity, it can be improved upon- made more silly, by building
3 of the following, thus presenting a capability of 18 cores / 36 threads @ 3.2 / 3.8 GHz. Using a single six core Xeon E5-1650, each system would have a Passmark CPU rating of No. 12, CPU score of 11462 each for a total processing power of 34386 or 160% of the single dual E5-2687w system. >
BambiBoom PixelDozer Cadaedimathagrapharific ExtremeSignature VI REV A ®©™®™©™_6.30.13
This system is intended as a workstation solution with high performance / high precision, very high stability / reliability at reasonable cost, and suitable for 2D and 3D CAD, graphic design, rendering, mathematics, simulation, animation, and video editing.
1. Xeon E5-1650 6-core 3.2 /3.8GHz, 12MB cache, LGA 2011 $600 (Passmark CPU score= 11462, rank = No. 12)
2. Noctua NH-U12S 120x120x25 ( NF-F12 PWM) SSO2-Bearing ( Self-stabilizing oil-pressure bearing ) CPU Cooler $70
3. ASUS P9X79 WS LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 SSI CEB $380.
4. 32GB (4X 8GB) 240-Pin DDR3 SDRAM DDR3 1600 ECC Unbuffered Server Memory > $300. (Check ASUS motherboard compatibility list)
5. NVIDIA Quadro K600 VCQK600-PB 1GB GDDR3 PCI Express 2.0 x16 Low Profile Workstation Video Card $160
6. SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) $134.99 (OS and Applications)
7. (2) Western Digital WD Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive ($180) $90 (Files, Backup, System Image)
8. SeaSonic X Series X650 Gold ((SS-650KM Active PFC F3)) 650W ATX12V V2.3/EPS 12V V2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply $120.
10. ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM $17.
TOTAL > $2,144. or for three systems >
$6,432.
The above system, with the substitution of a Quadro K4000, and three storage drives in RAID 5, and Windows 7 Professional was a concept for a system I would build for myself for industrial design work. I think however, I will wait for the next generation, 14nm Xeons and DDR4,... That series "Skylake" by the way is said to include 12 and 15 core CPU's!
As long as I'm entering the longest post in Tom's forum history competition, I may as well post a revised version of what I would consider a reasonable cost /performance, high performance system, also based on the Xeon 2687W, but with Tesla coprocessing- or which could be Xeon Phi (= + about $2,000). If you had specified a more or less unlimited budget, i.e. performance configured rather than cost /performance configured, for your proposed system, this would my suggestion >
BambiBoom CalcuCannon Cadaeditusimumathematica Extremesignature Modelistico $$+ IV ™®©$?™©_ 6.30.13 / REV a 7.3.13
The following configuration was done in consideration of the best performance and highest reliability basis suitable for the most demanding high calculation density requirements > Mathematical, Astrophysical, 2D and 3D dynamic CAD modeling and animation, molecular biology, static and dynamic structural, vector analysis, animation, particle, fluid, mechanical, and thermal simulation, rendering, graphic design > everything!
1. (2) Intel Xeon E5-2687W Sandy Bridge-EP 3.1GHz (3.8GHz Turbo Boost) 20MB L3 Cache LGA 2011 150W 8-Core Server Processor $3,868. ($1,934 each) On the Passmark CPU benchmark chart, this processor is the No.2 rated, score = 21491. In the top 100 systems on Passmark Performance test, this CPU is used in the 6th highest performing system (with Quadro 6000 (6GB).
2. (2) CORSAIR Hydro series H50 High Performance Liquid CPU Cooler ($120) ($59.99 ea) Liquid cooling is not typical for workstations, but having experience with long, sustained multiple CPU systems (CAD rendering which uses all cores), CPU temperatures can rise quickly to high levels.
3. Intel S2600COE SSI EEB Server Motherboard Dual LGA 2011 DDR3 1600 > $580. (Supports up to 512GB DDR3 ECC UDIMM/LV)
i.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121589
ii.
iii. Manual >
iv. Compatible Memory >
v. Review 2012 >
4. 256GB RAM (16x 16GB) 240-Pin DDR3 SDRAM DDR3 1600 ECC Registered Server Memory about $2700. (Check Intel motherboard / memory compatibility list)
5. PNY Quadro K5000 VCQK5000-PB Video Card - 4GB GDDR5, PCI-Express 2.0(x16), 1x Dual-Link DVI-D, 1x Dual-Link DVI-I, 2x DisplayPort, DirectX 11, Dual-Slot, Fan $1803.
6. NVIDIA Tesla K20 CUDA Coprocessor - 5GB GDDR5, PCI-Express 3.0 (x16), SMX, Dynamic Parallelism, Hyper-Q, Dual-Slot, Fan, $3261.
7. OCZ RVD3-FHPX4-480G RevoDrive 3 Series PCI-E Solid State Drive - 480GB, 4x PCI-Express $822. (Operating System (s) and Applications)
8. (3) Western Digital RE WD4000FYYZ 4TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Enterprise Internal Hard Drive $1230. ($409.99 each) (RAID 5) (Active files, backup, system image)
9. SeaSonic X-1250 1250W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply $254.99
10. LIAN LI PC-D8000 Black Aluminum ATX Full Tower Computer Case $331.99
TOTAL = about $14970, with Xeon Phi = about $17,000
Whew! I wonder if Tom's offers any "badges" for ridiculously long posts?
Cheers,
BambiBoom
My personal motto > "
No matter your wealth, power, or friends, the cheapest things in life are free."
