Picked out parts for my first build. Is there anything I should change?
G
Guest
Guest
Here are the parts
http://pcpartpicker.com/p/kN7MdC
Is there anything I should change? If so what do you suggest?
Also, I've been looking at the Acer H236HL monitor. Is this a good choice? What monitor under $200 would you recommend?
The psu is not very good. The 550w ts xfx is better and costs less but not modular. Not need for the wd black I'd get a wd blue or a Seagate barracuda. With savings from not getting the black you could get a evga b2 750w that would support a 2nd 970 in sli if you want to upgrade.
psu suggestions
http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
http://pcpartpicker.com/part/seasonic-power-supply-ssr550rm
http://pcpartpicker.com/part/xfx-power-supply-p1550bbefx
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
Monitor
It's just a bit over 200
http://pcpartpicker.com/part/acer-monitor-umfg6aab01
bignastyid
psu suggestions
Monitor
G
Guest
Guest
Okay thanks! Is this better? http://pcpartpicker.com/p/qt6Kgs
