Hello guys, I would like to ask you for a help with building new PC. I would like to avoid Intel (just because I could upgrade AMD CPU in 1 year without buying new mobo).
Usage:
Here is the build I am thinking of:
https://pcpartpicker.com/list/4zXyL2
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler
Motherboard: MSI MEG X570 ACE ATX AM4 Motherboard (or is there any better? I would like to have 2x GLAN, pls)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory
Storage: 2x Seagate BarraCuda 4 TB 3.5" 5400RPM Internal Hard Drive (just as data storage)
Storage: Gigabyte AORUS NVMe Gen4 1 TB M.2-2280 NVME Solid State Drive
Case: (I might upgrade to ekwb -cpu+gpu or monoblock+gpu in 6-8 months, so that's why I am thinking about that case)
Lian Li O11D XL-W ATX Full Tower Case
or
be quiet! Dark Base Pro 900 Rev. 2
or
NZXT H710i
or which case with good airflow (and glass panel) would you recommend me, please?
Power Supply: SeaSonic PRIME Ultra Titanium 850 W 80+ Titanium Certified Fully Modular ATX Power Supply (should I get Platinum or even Gold?)
Case Fans: 7x be quiet! SilentWings 3 PWM High-Speed 77.57 CFM 140 mm Fan
or
EK-Vardar X3M 120ER D-RGB (500-2200rpm) - White (EK-Loop Connect needed?)
Monitor: Gigabyte AORUS FI27Q-P 27.0" 2560x1440 165 Hz Monitor
GPU: I would like to buy just a cheap one right now, as I would buy new Nvidia's Ampere when it hits the market (till then I will play games via GeForce Now). So I would like to ask for which GPU I should go, please.
Keyboard: is there any good keyboard "like-a-laptop"? Minimum of noise, low keys etc.
Thank you very much for your help.
Usage:
- games at ultra settings (QHD monitor) -50% of time
- programming (HTML, CSS, JavaScript, Angular, React, Python, Java, C# - IntelliJ Idea, MS Visual Studio) - 20% of time
- Illustrator, Photoshop (with Wacom board) - 15% of time
- office work (Word, Outlook, Excel, browsing etc.) - 15% of time
or
or
NZXT H710i
or
