Hello guys and gals,
I am planning to build a new PC. I don't have any experience in this matter, but I've been reading articles and reviews of components released in the last 2 years.
After thinking over my actual needs, I came up with the build below. I think it could work, but i've got a few questions, hoping we could come up with something.
My intention is to build a PC capable of running smoothly softwares like SolidWorks, Cinema 4d, 3ds MAX - used for interior design, and furniture modelling - and pull off quick renderings.
PCPartPicker part list: http://pcpartpicker.com/list/RmwBZ8
Price breakdown by merchant: http://pcpartpicker.com/list/RmwBZ8/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($369.99 @ SuperBiiz)
Motherboard: ASRock X99M Extreme4 Micro ATX LGA2011-3 Motherboard ($199.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-3200 Memory ($189.99 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive ($109.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1080 8GB G1 Gaming Video Card ($629.99 @ SuperBiiz)
Case: BitFenix Phenom M Arctic White MicroATX Mini Tower Case ($81.78 @ Amazon)
Power Supply: Super Flower Leadex Gold 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($140.00)
Monitor: Philips BDM4065UC 40.0" 60Hz Monitor ($600.00)
Total: $2416.71
Generated by PCPartPicker 2016-08-04 03:53 EDT-0400
Case cooling possibilities:
Cooling Top 120mm x 2 (optional)
Cooling Bottom 120mm x 2 (1 included) or 200mm x 1(optional) or 230mm x 1 (optional)
Cooling Rear 120mm x 1 (included) or 140mm x 1 (optional)
The Questions:
1.) I don't think i can fit in a decent AIO liquid cooler in this case, to cool down the 5820k. I would also like to overclock the CPU a bit. So...what do you think, what kind of cooling solution would work best? It can also be air cooled as long as it gets the job done. Note: I really want to stick with this case!
2.) The second thing in question is the Memory. I don't know how much the mhz matters in the effectiveness of a ram. I don't plan to mess with overclocking the memory. I thought that a 3200 mhz kit should outperform a 2400 mhz kit, but I think it might produce too much heat for this case.
What are your insights guys?
3.) Could you please recommend me a fan setup to get a nice airflow in the case? - I plan to use a blower type card, for it to exhaust the heat right out of the case.
4.) TBH i'm not sure if the 1080 is an overkill or not. Would the 980 or 980 ti greatly underperform this badboy? In my country there is a €300 difference between the cheapest 980 and the cheapest 1080. Note: I am going to hook up a jumbo sized 4k monitor (40 - 43 inch) to the system.
Total: $2416.71
The Questions:
