Hey, I'm just wondering how a 20 pin pico psu works in a 24 pin socket... do embedded CPU MOBO need the extra 4 pins?
I'm looking into the AMD Zacate E350 1.6 GHz...
Any comments about this APU? is it good for a budget system?
How much will you fork out to buy a E350 System?
I have seen a 20 used in a 24 pin here : http://linitx.com/product/12635
At the last image...
is this safe?
I Here the E350 is really low in power , like 60W is the max you'll use... Is there a place that actually sells 60w PSU's - 90 is the smallest I can find.
Thanks for your time!
is this safe?
