picture on start up problem
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.windowsme.general (More info?)
Hi,
Some how I have a picture that appears at the very start of the start up
sequence on my Windows ME computer. It only lasts a second or so then goes
away and Windows then starts normally. how can I get rid of this or change
it? It is a picture that I have had on the computer and I have no idea how
it got into the start up sequence.
Cheers
Lenny
That sounds like it's the default wallpaper - try booting to Safe Mode, and
see if it's the wallpaper there - if so, then you should be able to change
it.
If not, then if you can remember the filename, change it to something else,
and Windows should drop back to a new default plain background.
Noel Paton (MS-MVP 2002-2005, Windows)
Nil Carborundum Illegitemi
http://www.btinternet.com/~winnoel/millsrpch.htm
http://tinyurl.com/6oztj
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
"lenny" <lenny109@takeout.hotmail.com> wrote in message
news:3LKdndbaz5qw4preRVnytQ@pipex.net...
> Hi,
> Cheers
> Lenny
Thanks noel, but it isn't the wallpaper it just flashes up for 1/2 second at
the very start of the start up sequence.
"Noel Paton" <NoelDPspamless@btopenworld.com> wrote in message
news:OS$cl1bpFHA.3516@TK2MSFTNGP15.phx.gbl...
> and see if it's the wallpaper there - if so, then you should be able to
> change it.
> else, and Windows should drop back to a new default plain background.
>> Hi,
>> goes away and Windows then starts normally. how can I get rid of this or
>> change it? It is a picture that I have had on the computer and I have no
>> idea how it got into the start up sequence.
>> Cheers
>> Lenny
This is 'normal' for Win ME - it's the ME 'splash' screen, which only ever
worked properly if you had your settings to US default (despite strenuous
efforts by Beta-testers to alert MS to the problem!).
If you are really desperate to rid yourself of it, do the following.
1) delete all files named
logo.sys
logow.sys
logos.sys
from the c:\ directory
2) modify MSDOS.SYS to indicate that you don't want the splash screen to
show - I can't personally see any point to this, since the default screen
is at least telling you which OS is booting, so if you want to know how to
do it, search Google.
news:9uWdnUQSJeR_d5TeRVnyrg@pipex.net...
> at the very start of the start up sequence.
>> change it.
>>> Hi,
>>> Cheers
>>> Lenny
Thanks Noel,
I don't mind the splash screen I just don't want this particular picture. It
isn't the default one but one of my own.
So if I do Part 1 of your suggestion will it revert back to default?
As you may tell the ME com[puter is in another location or I would try it
straight away.
Cheers
Lenny
news:eUdvTf0pFHA.3576@TK2MSFTNGP09.phx.gbl...
> logo.sys
> logow.sys
> logos.sys
>>> change it.
>>> NG's
>>>> Hi,
>>>> up sequence on my Windows ME computer. It only lasts a second or so
>>>> then goes away and Windows then starts normally. how can I get rid of
>>>> this or change it? It is a picture that I have had on the computer and
>>>> I have no idea how it got into the start up sequence.
>>>> Cheers
>>>> Lenny
Yup - deleting the named files will revert all to the default.
news:Q8qdnfONucltHJDeRVnyhw@pipex.net...
> Thanks Noel,
> It isn't the default one but one of my own.
> straight away.
> Cheers
> Lenny
>> ever worked properly if you had your settings to US default (despite
>> strenuous efforts by Beta-testers to alert MS to the problem!).
>> logo.sys
>> logow.sys
>> logos.sys
>> screen is at least telling you which OS is booting, so if you want to
>> know how to do it, search Google.
>>> second at the very start of the start up sequence.
>>>> change it.
>>>> NG's
>>>>> Hi,
>>>>> Cheers
>>>>> Lenny
Thanks for that. I have deleted the files as suggested and it worked.
Cheers
Lenny
news:eaQAbUaqFHA.3680@TK2MSFTNGP15.phx.gbl...
>> Thanks Noel,
>> straight away.
>> Cheers
>> Lenny
>>> logo.sys
>>> logow.sys
>>> logos.sys
>>> to show - I can't personally see any point to this, since the default
>>> NG's
>>>>> Mode, and see if it's the wallpaper there - if so, then you should be
>>>>> able to change it.
>>>>> NG's
>>>>>> Hi,
>>>>>> and I have no idea how it got into the start up sequence.
>>>>>> Cheers
>>>>>> Lenny
Glad to hear it!!
Thanks for the feedback.
news:F_udnfJVAfV015LeRVnyiw@pipex.net...
> Cheers
> Lenny
>>> Thanks Noel,
>>> picture. It isn't the default one but one of my own.
>>> it straight away.
>>> Cheers
>>> Lenny
>>>> logo.sys
>>>> logow.sys
>>>> logos.sys
>>>> NG's
>>>>>> able to change it.
>>>>>> NG's
>>>>>>> Hi,
>>>>>>> start up sequence on my Windows ME computer. It only lasts a second
>>>>>>> or so then goes away and Windows then starts normally. how can I get
>>>>>>> rid of this or change it? It is a picture that I have had on the
>>>>>>> computer and I have no idea how it got into the start up sequence.
>>>>>>> Cheers
>>>>>>> Lenny
