Piggy Backing SATA Power
Ertrius
109
I just purchased the last components needed for my first PC build. The HDD and the Blu-Ray drive need to be connected to SATA power. Can I piggy back these two together using a 2-way or 3-way SATA cable? I`m just wondering if it matters which components can share a SATA cable, and if some components should be connected on it`s own power cable.
Okay, thanks for the quick answer, but I misstated the power for the HDD. It is not SATA. It is SATA 6 Gb/s. So, I`ll share the optical drive power with an existing SATA 3-way cable, and use a SATA 6 Gb/s cable for the HDD. Is this right?
