Ping: misfit--comp problems
G
Guest
Guest
Archived from groups: alt.games.diablo (More info?)
Well I found a new board online to replace the broken one and I got it
put in, plugged in the chips and connectors and now the CD/ROM drive
wont read discs, which mean I can't play : (
I suppose I could plug the Mac back in, but its a pain to keep
switching back and forth and our network isnt compatible with the old
pre OSX Mac, so I cant run them at the same time.
Any ideas on the disc drive?
Sean
BTW, the board I replaced is the big flat one on the bottom (if the
comp is on its side) that everything else plugs into. I think its
called the processor. I checked the plugs from the disc drive and its
hooked up.
it
> Sean
its
> hooked up.
That would be your motherboard. Now, while being totally illiterate
when it comes to fruit based computers, this does sound like a problem
with the drivers.
Mickey
Actually this is a Dell PC that I replaced the board. It broke shortly
after the warranty expired, literally broke. There are two wire loops
epoxied into the board that hold a retaining wire that keeps a heat
sink down. One of the loops popped loose, hence the board needed
replacing, since I was told that attempting to repair it would mess up
the circuitry. Now that the CD ROM drive wont read discs, D2 is
unusable.
I guess I should have just upgraded to a newer, fruit-based model. I
understand them. And they don't "break".
Sean
"unklbob" <mcgriswald@aol.com> wrote in message
news:1114476320.295842.275700@o13g2000cwo.googlegroups.com...
Then you're not dropping it from high enough up.
There are seperate connections for the HDD and CDROM, so the
master/slave thing doesnt apply. As for the processor/heat sink, It
comes as a one piece kit from Dell, but the pinned assembly will come
apart when you remove the heat sink from the mobo. I carefully
reassembled it, making sure the pins and holes lined up before I
replaced the heat sink/fan/ processor.
The system runs on windows nt.
I don't think the CD drive is worn out, since it was working fine just
prior to the heat sink problem, and it had been replaced under warranty
not six months prior. Mickey suggested the driver, and I think I am
going to check the Dell site and reload them, although I dont have a
clue if it will work, since the HDD is working fine.
Sean
> warranty not six months prior. Mickey suggested the driver, and I
> think I am going to check the Dell site and reload them, although I
> dont have a clue if it will work, since the HDD is working fine.
CDROM drives don't need drivers per se. It's handled at a low-level,
sub-operating system by the BIOS on the mobo. Windows just finds it and uses
it, no device driver needed.
Unfortunately NT is one of the few MS OSes that I'm not familiar with. I'd
check connections first and make sure it's set to master or single if it's
the only device on the IDE ribbon. Is the BIOS recognising it? Does it show
up on the boot screen? Sort of like: "Found CDROM NEC2435" or similar. I
think it's either hardware related (As that's what you've changed. You
haven't reinstalled Windows have you?). Or it's BIOS related. The BIOS comes
on the mobo and the settings on the new one may not be identical to the
settings on the old one. (BIOS = Basic Input/Output System and is located on
a flash ROM chip on the mobo. You can access it during boot-up, usually by
pressing <delete> after it beeps).
Good luck, post back if I can help more. I think cabling personally. Most
BIOS's pick up a CDROM without any settings being changed. It's either
cabling or the second IDE channel on the mobo is hosed.
~misfit~
If I had it in front of me I'd probably have it fixed before I finished a
coffee. However remote troubleshooting is a whole different kettle of fish.
"~misfit~" <misfit61nz@hooya.co.nz> wrote in message
news:d4n24s.230.1@fairground.synaptic.net.nz...
> uses
> show
> comes
> on
<F2> is also a popular BIOS launcher on Intel boards. (Dang, I missed the
NT reference first time through. That's my playground.) Unplug the CD
entirely - if the system boots and runs smoothly, it strongly points to
jumpers and BIOS settings. The factory BIOS might still have a old
configuration, with the CD set on the other connector on something. Setting
both the IDE channels to Auto and rebooting might wake the system back up.
While you're in there, set "Plug and Play OS" to "No". Change the parallel
port to anything other than "Auto". NT lives in a world all it's own.
> ~misfit~
> fish.
....a kettle that's been left in the sun for a few days...
Zamboni
>> just prior to the heat sink problem, and it had been replaced under
> and uses it, no device driver needed.
> with. I'd check connections first and make sure it's set to master or
> single if it's the only device on the IDE ribbon. Is the BIOS
> recognising it? Does it show up on the boot screen? Sort of like:
> "Found CDROM NEC2435" or similar. I think it's either hardware
> related (As that's what you've changed. You haven't reinstalled
> Windows have you?). Or it's BIOS related. The BIOS comes on the mobo
> and the settings on the new one may not be identical to the settings
> on the old one. (BIOS = Basic Input/Output System and is located on a
> by pressing <delete> after it beeps).
> Most BIOS's pick up a CDROM without any settings being changed. It's
> either cabling or the second IDE channel on the mobo is hosed.
Another option to check is that the secondary IDE channel is enabled, I have
seen some mb's that have it disabled by default, to access the BIOS, press
the <del> key at start-up.
Craig
