Ping spikes momentarily and periodically. I think it might be an issue with my mobo, need opinions
Vladimir_2
8
Hey guys, I have been trying to diagnose a problem for nearly two months now and I am finally admitting defeat. I hope that someone here can take a crack at my problem and possibly do better than I did. The problem is that my ping spikes up to 300-500 and sometimes 1k+ almost every 20 seconds for 1-2 seconds, otherwise the ping is stable at 36-44. When browsing online, it's hardly noticeable but infuriating when playing online games. I've tried using network card, wired, and wireless adapter (i'm on desktop). The only consistent one was the wireless adapter with the ping range between 90-130 and no higher. At that ping range, I can play my games but there is some lag which is infuriating but not so much as the massive lag spikes experienced from wired/NIC. I pinged my router when on NIC and the result is pasted below:
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=312ms TTL=64
Reply from 192.168.1.1: bytes=32 time=10ms TTL=64
Reply from 192.168.1.1: bytes=32 time=446ms TTL=64
Reply from 192.168.1.1: bytes=32 time=112ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=142ms TTL=64
Reply from 192.168.1.1: bytes=32 time=277ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 1183, Received = 1183, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 731ms, Average = 21ms
There were way more pings but I had to condense it down to fit in the message. Wired and NIC behaved pretty much the same, but it was different on adapter. Since NIC and Wired were directly on the mobo, I think it's a motherboard problem, but I can't say for sure. My mobo is Maximus hero vii, and I had just updated the bios recently. I've also updated all the PCE drivers, and I believe all of my LAN drivers are updated as well. At least none of those are being flagged as outdated on drivermax. I don't believe that it's my ISP, but there may be a culprit that I'm overlooking. Please help me, I'm really desperate at this point.
Just a friendly tip, if you start your conputer in safe mode with networking and go online and whatnot, if you notice you don't have any ping spikes or latency drops then you know it's not system files, services, or drivers.
This will mean is a 3rd party program causing the latency drops. Meaning anything from installers to game downloaders, Downloader period, this is why you monitor the network traffic and see what is using up your net. You end that program. Find out what it is aND get rid of it.
Alot of times it ends up being anti virus programs
Since all the windows 10 updates even to 7 and 8 to prepare it. Avg, and Symantec have been the most prominent for these kind of things as I have noticed personally.
You need to call your ISP to have them test the internet. This is one of the most difficult problems to have on internet, if your not using a 5g channel i would recommend changing the channel of your 2.4ghz, ping spikes can occur when any type of interference from telephones to microwaves are in the vicinity.
You could also be suffering from packet collision, this typical results in ping spike and loss of packets for a brief moments, Miliseconds. I would make sure that your internet adapter driver is the most up to date it can be. As this can also cause it.
This is where you get the latest drivers for your adapter https://downloadcenter.intel.com/product/71305/Intel-Ethernet-Connection-I218-V
You can also use your GameFirst III to give more bandwidth to you while gaming. as this does come with a network monitor aswell.
I don't believe that this is an ISP issue because adapter is fine whereas NIC and Wired are not. I am on 5g channel, but I swapped to 2.4g to check it out just now and the issue persists.
Hm packet collision? How do I go about diagnosing that? I checked out GameFirst III but I couldn't find any download links for it. Does this come with the mobo in the form of a cd?
Yes, its on your original Mobo CD that you got with the MOBO.
Please goto Start --> Run --> type services.msc and press OK --> Click on Action and then Export List.. --> Save it to an easy-to-reach location as services.txt --> Open up that text file, and copy/paste the results into your next reply.
I ran the cd that the mobo came with. There is no option to install GameFirst 3. I will check the net to see if there is a download link for it, but I don't think it will be the solution to the problem.
Below is the result:
Name Status Startup Type Log On As
Background Tasks Infrastructure Service Running Automatic Local System
Windows Firewall Running Automatic Local Service
Tile Data model server Running Automatic Local System
Print Spooler Running Automatic Local System
Program Compatibility Assistant Service Running Automatic Local System
Windows Event Log Running Automatic Local Service
User Profile Service Running Automatic Local System
Network Store Interface Service Running Automatic Local Service
WLAN AutoConfig Running Automatic Local System
Security Accounts Manager Running Automatic Local System
Remote Procedure Call (RPC) Running Automatic Network Service
Diagnostics Tracking Service Running Automatic Local System
Diagnostic Policy Service Running Automatic Local Service
DCOM Server Process Launcher Running Automatic Local System
Base Filtering Engine Running Automatic Local Service
COM+ Event System Running Automatic Local Service
Server Running Automatic Local System
NVIDIA Streamer Service Running Automatic Local System
RPC Endpoint Mapper Running Automatic Network Service
DHCP Client Running Automatic Local Service
Themes Running Automatic Local System
Cryptographic Services Running Automatic Network Service
NVIDIA Stereoscopic 3D Driver Service Running Automatic Local System
NVIDIA Display Driver Service Running Automatic Local System
Shell Hardware Detection Running Automatic Local System
Windows Image Acquisition (WIA) Running Automatic Local Service
Windows Management Instrumentation Running Automatic Local System
Windows Font Cache Service Running Automatic Local Service
NVIDIA Network Service Running Automatic Local System
NVIDIA GeForce Experience Service Running Automatic Local System
System Event Notification Service Running Automatic Local System
Power Running Automatic Local System
DisplayLinkManager Running Automatic Local System
CoreMessaging Running Automatic Local Service
Bluetooth Driver Management Service Running Automatic Local System
Windows Audio Running Automatic Local Service
Windows Audio Endpoint Builder Running Automatic Local System
MBAMService Running Automatic Local System
MBAMScheduler Running Automatic Local System
Distributed Link Tracking Client Running Automatic Local System
Superfetch Running Automatic Local System
Task Scheduler Running Automatic Local System
Bitdefender Desktop Update Service Running Automatic Local System
Workstation Running Automatic Network Service
Local Session Manager Running Automatic Local System
Network Location Awareness Running Automatic Network Service
Bonjour Service Running Automatic Local System
ASUS Com Service Running Automatic Local System
ASUS System Control Service Running Automatic Local System
Bitdefender Virus Shield Running Automatic Local System
BlueStacks Log Rotator Service Running Automatic Local System
BlueStacks Updater Service Running Automatic Local System
GamingApp_Service Running Automatic Local System
MSI_LiveUpdate_Service Running Automatic Local System
Razer Game Scanner Running Automatic Local System
Skype Updater Automatic Local System
Background Intelligent Transfer Service Running Automatic (Delayed Start) Local System
Security Center Running Automatic (Delayed Start) Local Service
Windows Search Running Automatic (Delayed Start) Local System
Downloaded Maps Manager Automatic (Delayed Start) Network Service
Delivery Optimization Automatic (Delayed Start) Local System
dmwappushsvc Automatic (Delayed Start, Trigger Start) Local System
Software Protection Automatic (Delayed Start, Trigger Start) Network Service
User Manager Running Automatic (Trigger Start) Local System
Group Policy Client Running Automatic (Trigger Start) Local System
IKE and AuthIP IPsec Keying Modules Running Automatic (Trigger Start) Local System
DNS Client Running Automatic (Trigger Start) Network Service
Windows Connection Manager Running Automatic (Trigger Start) Local Service
Device Association Service Running Automatic (Trigger Start) Local System
System Events Broker Running Automatic (Trigger Start) Local System
Windows Biometric Service Automatic (Trigger Start) Local System
WMI Performance Adapter Disabled Local System
Net.Tcp Port Sharing Service Disabled Local Service
Routing and Remote Access Disabled Local System
Smart Card Disabled Local Service
Remote Registry Disabled Local Service
WinHTTP Web Proxy Auto-Discovery Service Running Manual Local Service
Diagnostic System Host Running Manual Local System
Diagnostic Service Host Running Manual Local Service
Credential Manager Running Manual Local System
State Repository Service Running Manual Local System
NVIDIA Streamer Network Service Running Manual Network Service
Network List Service Running Manual Local Service
Plug and Play Running Manual Local System
SSDP Discovery Running Manual Local Service
Windows Remote Management (WS-Management) Manual Network Service
Windows Connect Now - Config Registrar Manual Local Service
Update Orchestrator Service Manual Local System
Xbox Live Game Save Manual Local System
Work Folders Manual Local Service
Xbox Live Networking Service Manual Local System
PNRP Machine Name Publication Service Manual Local Service
Problem Reports and Solutions Control Panel Support Manual Local System
Printer Extensions and Notifications Manual Local System
Windows Event Collector Manual Network Service
WWAN AutoConfig Manual Local Service
Adobe Flash Player Update Service Manual Local System
Windows Push Notifications Service Manual Local System
BranchCache Manual Network Service
Wired AutoConfig Manual Local System
Windows Color System Manual Local Service
Block Level Backup Engine Service Manual Local System
Retail Demo Service Manual Local System
Function Discovery Provider Host Manual Local Service
Extensible Authentication Protocol Manual Local System
Steam Client Service Manual Local System
Windows Media Player Network Sharing Service Manual Network Service
Remote Desktop Configuration Manual Local System
SNMP Trap Manual Local Service
Quality Windows Audio Video Experience Manual Local Service
Function Discovery Resource Publication Manual Local Service
Windows Backup Manual Local System
ActiveX Installer (AxInstSV) Manual Local System
IP Helper Manual Local System
Telephony Manual Network Service
Secure Socket Tunneling Protocol Service Manual Local Service
Application Layer Gateway Service Manual Local Service
Internet Connection Sharing (ICS) Manual Local System
Virtual Disk Manual Local System
AppX Deployment Service (AppXSVC) Manual Local System
Peer Networking Identity Manager Manual Local Service
Xbox Live Auth Manager Manual Local System
Application Management Manual Local System
Device Management Enrollment Service Manual Local System
Performance Logs & Alerts Manual Local Service
Windows Presentation Foundation Font Cache 3.0.0.0 Manual Local Service
GalaxyCommunication Manual Local System
COM+ System Application Manual Local System
Microsoft Software Shadow Copy Provider Manual Local System
Network Connections Manual Local System
Microsoft iSCSI Initiator Service Manual Local System
Remote Access Connection Manager Manual Local System
Volume Shadow Copy Manual Local System
HomeGroup Listener Manual Local System
Netlogon Manual Local System
Still Image Acquisition Events Manual Local System
Google Update Service (gupdate) Manual Local System
Google Update Service (gupdatem) Manual Local System
Intel(R) Integrated Clock Controller Service - Intel(R) ICCS Manual Local System
Remote Procedure Call (RPC) Locator Manual Network Service
WalletService Manual Local System
Microsoft Storage Spaces SMP Manual Network Service
Optimize drives Manual Local System
Windows Defender Service Manual Local System
Windows Defender Network Inspection Service Manual Local Service
Google Software Updater Manual Local System
GalaxyClientService Manual Local System
App Readiness Manual Local System
Internet Explorer ETW Collector Service Manual Local System
Fax Manual Network Service
Interactive Services Detection Manual Local System
Secondary Logon Manual Local System
Peer Name Resolution Protocol Manual Local Service
Performance Counter DLL Host Manual Local Service
Peer Networking Grouping Manual Local Service
Windows Modules Installer Manual Local System
Enterprise App Management Service Manual Local System
Microsoft (R) Diagnostics Hub Standard Collector Service Manual Local System
Link-Layer Topology Discovery Mapper Manual Local Service
Remote Access Auto Connection Manager Manual Local System
Certificate Propagation Manual Local System
Distributed Transaction Coordinator Manual Network Service
CDPSvc Manual Local Service
Bitdefender Desktop Parental Control Manual Local System
Remote Desktop Services Manual Network Service
UPnP Device Host Manual Local Service
Smart Card Removal Policy Manual Local System
Remote Desktop Services UserMode Port Redirector Manual Local System
Windows Installer Manual Local System
BlueStacks Android Service Manual Local System
Geolocation Service Running Manual (Trigger Start) Local System
CNG Key Isolation Running Manual (Trigger Start) Local System
Bluetooth Support Service Running Manual (Trigger Start) Local Service
TCP/IP NetBIOS Helper Running Manual (Trigger Start) Local Service
Windows License Manager Service Running Manual (Trigger Start) Local Service
Client License Service (ClipSVC) Running Manual (Trigger Start) Local System
Application Information Running Manual (Trigger Start) Local System
Windows Update Running Manual (Trigger Start) Local System
DevQuery Background Discovery Broker Running Manual (Trigger Start) Local System
Windows Driver Foundation - User-mode Driver Framework Running Manual (Trigger Start) Local System
Time Broker Running Manual (Trigger Start) Local Service
Network Connection Broker Running Manual (Trigger Start) Local System
Human Interface Device Service Running Manual (Trigger Start) Local System
Windows Encryption Provider Host Service Manual (Trigger Start) Local Service
Spot Verifier Manual (Trigger Start) Local System
Offline Files Manual (Trigger Start) Local System
Network Setup Service Manual (Trigger Start) Local System
DataCollectionPublishingService Manual (Trigger Start) Local System
Hyper-V Time Synchronization Service Manual (Trigger Start) Local Service
Microsoft Windows SMS Router Service. Manual (Trigger Start) Local System
AllJoyn Router Service Manual (Trigger Start) Local Service
Encrypting File System (EFS) Manual (Trigger Start) Local System
Windows Mobile Hotspot Service Manual (Trigger Start) Local Service
Microsoft Passport Manual (Trigger Start) Local System
Windows Store Service (WSService) Manual (Trigger Start) Local System
Storage Service Manual (Trigger Start) Local System
Network Connectivity Assistant Manual (Trigger Start) Local System
Data Sharing Service Manual (Trigger Start) Local System
Hyper-V Guest Service Interface Manual (Trigger Start) Local System
Hyper-V Remote Desktop Virtualization Service Manual (Trigger Start) Local System
Hyper-V Guest Shutdown Service Manual (Trigger Start) Local System
Hyper-V VM Session Service Manual (Trigger Start) Local System
Hyper-V Data Exchange Service Manual (Trigger Start) Local System
File History Service Manual (Trigger Start) Local System
HomeGroup Provider Manual (Trigger Start) Local Service
Network Connected Devices Auto-Setup Manual (Trigger Start) Local Service
Sensor Monitoring Service Manual (Trigger Start) Local Service
Hyper-V Heartbeat Service Manual (Trigger Start) Local System
Microsoft Passport Container Manual (Trigger Start) Local Service
Windows Time Manual (Trigger Start) Local Service
Computer Browser Manual (Trigger Start) Local System
IPsec Policy Agent Manual (Trigger Start) Network Service
Portable Device Enumerator Service Manual (Trigger Start) Local System
Bluetooth Handsfree Service Manual (Trigger Start) Local Service
WebClient Manual (Trigger Start) Local Service
Microsoft Account Sign-in Assistant Manual (Trigger Start) Local System
Touch Keyboard and Handwriting Panel Service Manual (Trigger Start) Local System
Device Setup Manager Manual (Trigger Start) Local System
Device Install Service Manual (Trigger Start) Local System
embeddedmode Manual (Trigger Start) Local System
Application Identity Manual (Trigger Start) Local Service
Sensor Data Service Manual (Trigger Start) Local System
Smart Card Device Enumeration Service Manual (Trigger Start) Local System
KtmRm for Distributed Transaction Coordinator Manual (Trigger Start) Network Service
Hyper-V Volume Shadow Copy Requestor Manual (Trigger Start) Local System
BitLocker Drive Encryption Service Manual (Trigger Start) Local System
Windows Error Reporting Service Manual (Trigger Start) Local System
Sensor Service Manual (Trigger Start) Local System
Edited: Removed description
That's one hell of a clutter. Should I have posted the standard tab instead?
Click on Start > type "services.msc" in the search field and press enter. In the "Services" window, look for the following entry: SSDP Discovery. Double click and set the "Startup type" as "Disabled"
also set Backround Intellegent Transfer Service to Disabled,
Disable "IP Helper"
After can you please open task manager, go to network, and take a screenshot of all the network utilization and post?
This almost has to be a driver issue. Normally I would be asking....do you have a killer chipset....but you have intel which tends to be very stable.
The killer chipset tries to prioritize game traffic over other. The so called gamefirst from intel does the same but it is not as integrated into the driver as killer is. These type of software tend to cause all kinds of strange issues and are best not used.
These types of software are only useful for very stupid people. You would only need this when you are sending large amounts of data from your pc at the same time you are playing games and need the game to have priority. If you are worried about game performance why would you be stupid enough to run a large file transfer at the same time in the first place. Its easier to just not do stupid stuff than to try run software to bail you out.
If this is a windows 10 system you need to search for drivers that say they are compatible with windows 10. You want to try to use the motherboard drivers first before you try the ones from intel. The one you want to avoid are the ones from microsoft that are built into windows 10 these tend to have the most strange issues.
You could I suppose try to ping another machine in your house or maybe ping the router from a different machine just to be sure it is not the router. Delays like this are very strange in a lan environment because equipment generally can not hold data that long.
I did as you suggested and below was the result:
hgxFQyF
Unfortunately the problem persists 🙁
Edit: I have no idea why the picture isn't showing. The link is http://imgur.com/hgxFQyF
Haha yea, it's never a good idea to play games online games while downloading massive files. I'm sure someone out there has other uses for the application though.
The problem persists between him and communication between the router.
Open cmd prompt
Type ipconfig /release
Type ipconfig /Flushdns
Type ipconfig / renew
Also in your router setti ng s usually 192.168.x.1 x being 1,2,3,4 usually the lower ones.
Once inside you can turn off ip flood detection and alter a few other setting like increasing the TX power to high, then ontop of that change the fragmentation to the best settiing for you to avoid packet collisions if someone else is also on the web.
I tried those command prompts and had no luck. I also booted the computer on safe mode with network but I had no internet connection at all on safe mode despite the fact. Are we on to something here?
Edit: Nevermind, I'm connected to the internet. The icon showed that I wasn't but I actually am. So far I'm seeing some spikes at the 130 range but nothing higher. This is looking good! I'll let the ping run for a couple more minutes.
Edit: Stable internet connection on Safe mode w/ network. Logged back on to normal mode and closed apps while monitoring the ping. Got to the AV (Bitdefender) and disabled it. Ping is looking stable now! So I think the problem might be AV. Do you know how I can go about fixing this or do I have to ditch Bitdefender entirely?
Ditch bit defender, delete that thing please! Download Avast free antivirus, its a great program. I am very happy I could help you solve your internet spikes. I had a suspicion it was an AV causing it.
Thank you, I really appreciate your help!
For anyone reading this in the future, setting BitDefender to Game Profile or ditching it altogether may solve your ping spikes!
