Can't give you an exact answer without the model of the TV.
Since the receiver only has analog audio outputs that would be the easiest connection. Many Sony TVs have a hybrid headphone line level audio output. You just need a cable with 3.5mm stereo plug at the TV and 2 RCA plugs at the receiver. Use any input except phono.
If the TV only has optical audio out you will need one of these http://www.parts-express.com/parts-express-dac-digital-to-analog-converter-(51-compatible)--180-999
On many TVs you will have to turn the optical out on, turn the TV speakers off and change the audio output type to get it to work.
