I have a Antec P180B case with an ASUS P5W DH Deluxe mobo coupled with a Core 2 Duo E6600. I also have an ATI X1900XT in there. Ok, well, I wanted a quiet system and to accomplish that, I had to replace the ATI cooler with something quieter. I chose the Accelero X2 which works great, except for it dissipates the heat onto the motherboard. Well, the south bridge is fairly close to the PCI Express slot and the heat from the gfx card has reached the sb. Therefore, I placed a fan (120mm) on the middle HDD cage to cool it. Afterwards, I decided to get a better cooling solution for my CPU since my load temps were in the mid 60s. Hence, I got the Thermaltake Silent Water...
<b>Now, here's the problem!</b>
I placed the fan/pump/radiator on the back of the case, which was ok, because I still had the top fan hooked up. Now, my motherboard came with a fan for the northbridge since the northbridge relies on the CPU fan for cooling. But with the fan/pump/radiator on the back of the case, I couldn't place the fan that came with the motherboard. Therefore, I bought 2 40mm fans and placed them on the nb and sb (after I removed the stupid ASUS covers from both the heatsinks). Afterwards, my temps for the CPU were still high. It occurred to me that this is probably due to the fact that the heat within the case is being sucked through the radiator, which doesn't really help cooling. Therefore, I removed the removable HDD cage and placed the fan/pump/radiator to the front of the case. This allows for <b>FRESH</b> air to blow across the radiator. But guess where the heat goes? Yup! Right back into the case... And the placement of the fan/pump/radiator is at level with the gfx, which blows more hot air into the case. So, what's the best way to set up the inside of the case, so that I can get more heat out of it? My CPU stays cool, but now the components in the case get warmer. The top and rear fan don't seem to help much. All in all, I have 2 fans (top and rear) mounted to the back, 1 fan is part of the radiator and pump. This totals out to 3 120mm fans now. Then, I have 2 40mm fans on the nb and sb and the ASUS fan on the heatsink next to the CPU. Then there's the fan on the Accelero (quiet) and the OCZ GameXStream fan (noisy), which helps pull cool air from the front of the case across my hard drives ( I removed the middle fan on the bottom shaft). So, what can I possibly do now?!
Any ideas and suggestions are welcome!
