Plan to build system tell me what you think
ChiefNMike87
- Intel Core i7-4820K Ivy Bridge-E 3.7GHz (Turbo 3.9GHz) LGA 2011 130W Quad-Core Desktop Processor BX80633i74820K
- ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- EVGA 04G-P4-2768-KR GeForce GTX 760 4GB 256-bit GDDR5 PCI Express 3.0 SLI Support SC 4GB w/ EVGA ACX Cooler Video Card
- NZXT HALE90 V2 NP-1GM-0850A 850W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS GOLD Certified Full Modular Active@0.99(Typically) ...
- G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9Q-16GBRL
- Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
I plan on using my old HD and disk drives. The specific questions I have are A) Does any one see any compatibility issues? B) is the PSU I selected overkill? C) Should I go with 1833 memory instead of 1600 and D) Is this CPU cooler good enough for gaming applications or should I go with something else? Oh and if anyone is feeling in the xmas mood this does double as a wish list =)
If not thinking of SLI in the future then the 850 is a bit of OK yes, for a 760 and your Rig a 550 w/ 30 AMPs on the 12 Volt rail, yep - I'd go 1866, might look at the Snipers with your rig, 1866/9 or even 2133/9 or 10, 1600 is basically entry level, and we'll stick you on the Xmas list, think you'll fall in at number 104,372 - so there's just a few ahead of you 😉
thanks for your answers I think my only option for ram is 1600 an 1866 but ill have to check to be sure and yes I plan on SLI in future. I do realize processor is overkill but that is a part that I would rather buy a cpu once and keep it till it fails instead of spending less and having to upgrade when it cant keep up with software. but again thanks for you input guys
