Planar 27" QHD Monitor Review: Clarity Like We've Never Seen
16.2ms SMTT reviewed catleap or crossovers from greensum/korea LG S-IPS have been out for well over 2 years now at a $300 or less starting price. Get with the times toms.
I agree with stoogie - also Toms needs to get an Overlord tempest and take a look at a real gaming 1440 panel that can do up to 120hz refresh rates. This screen isn't that special and the housing has been around in other variants for a year now as well.
445 cd/m2 of luminance as maximum and 174.7655 cd/m2 as minimum ? Why do monitor manufacturers insist on delivering brighter and brighter monitors ? People don't use them like they are on display in a very well lit showroom, if you want to use one of these at home with just an indirect light source on the wall for some gaming at night, you're out of luck, this doesn't even reach the industry standard of 120 cd/m2 as adequate regular brightness, let alone the 50 cd/m2 that Tom's and many others consider an acceptable minimum to have in a darker room.
What do you seriously think that another 27" 2560x1440 60Hz monitor that is already in class with a dozen other models identical to it, deserves an award?
Looks exactly like the "new" QHD Iiyama. Doesn't perform well. Costs a lot. What's the advantage, again?
As for those overlord monitors, I wasn't impressed by them, mostly because I had it sitting next to a lightboost 2 120hz TN panel. Yes, the overclocked IPS panel has better colour (though that's largely negated by using it on minimal brightness in a dark room, like we've already been talking about), and it's certainly pretty and gives a lot of screen real estate... but it can't compare to a real 120Hz monitor, especially not one with a strobing backlight.
"With the new PXL2790MW, we quickly discovered there was no need for scaling in any program. The image is so clear that even the smallest text is fully legible." Technically admirable, but not enough for people like me with middle-aged eyes. The more pixels per inch, the happier my eyes are, but they still want decent-sized fonts.
Now this sort of monitor clarity plus an OS that supports decent enlarged fonts would be really nice. Apps that scale well over a range of sizes would be even nicer. A 1000 pixel wide frame may be good for some people no matter how small it is; others of us would like at least a certain number of inches. Support all of us.
(Yes, I know that this isn't the monitor's fault. It's a poor convention in many parts of the software industry.)
I have never had a major problem with text clarity with pretty much any LCD since the first thing I make sure to do is set the panel or monitor to native resolution hardware scaling and turn off all windows text or font smoothing and windows set to the same monitor native resolution. I haven't seen one of these 2560 screens in person but I have experienced the default font issue that happens when you try and let windows smooth or scale. I don't like monitors with radiused corners because that makes the bezels even thicker then they need to be. I also don't like the way most monitor manufacturer try to hide the input plugs by making them inset and pointing down. It is a pain to try to plug or unplug anything when you can't see the plug without laying the monitor on its side. Also it makes no use to label the inputs if they are inset dark on dark. Make the text white.
When you say a real 120Hz - I don't get that. I have both 248s and Tempests and I prefer the Tempest all day every day. Monitors are clearly very subjective. Some people complain about strobing, PWm, etc. but it doesn't affect me at all. I prefer an IPS panel over a TN panel. The Tempest is a real 120hz monitor once OC'd so your comment makes little sense to me. Gaming on an IPS 1440 is much preferred and the added Hz makes the overlord the best gaming display for me.
Got my new LG 27EA83R-D colorprime factory calibrated QHD, for $550.00. Gaming, surfing, really everything at QHD is amazing and if you sit in front of your monitor like I do you won't go back to 1080P at 27". It's a pixelated joke.
And this notion that 120hz is some profound requirement and experience for gaming is a joke. Just like the hype you get from Best Buy, there is no predominant, visible difference between 60 and 120Hz that you don't have to work hard to notice any difference. I bought and sold a state of the art Asus 120Hz TN 27" "gaming" panel. Don;t buy into the 120Hz hype. It's way overrated hyperbole. You will notice a profound difference with a 60Hz QHD screen with EVERYTHING you do with it. You'll love it every single day!
Herpa Durp? QHD has been ready for "gaming prime time" for years now. Fortunately, panels are coming down in price and adoption is increasing as a result.
Your argument would be totally valid for 4K displays right now...excessively expensive, complicated input requirements, killer HW requirements. Very much a niche market.
1440p is **like** totally the new 1080p. Psshhya
It's not a real 120hz display i.e. designed for it. It has significantly more latency, and serious issues with motion blur... where a monitor designed for high refresh rates has virtually no input lag, and (if using lightboost technology set up to strobe), zero motion blur. An overclocked ips panel is still better than a non-overclocked ips panel, but I'll take a TN panel any day. The very high end TN panels look nearly as good as lower-end IPS panels, yet perform way better... and IPS panels don't handle being set to low brightness very well. I agree that IPS is superior for certain things; most notably tasks that require color accuracy. But for a gaming setup, I disagree. (Though a 1440p monitor, you're right, is a wonderful thing.)
That... is absolutely not true. Have you set your monitor up with lightboost, if you aren't using it? Have you gone into windows and your video drivers and told them to run the monitor at 120hz? Most of the time, when people say they can't see the difference between 120hz and 60hz, it's because they didn't set it up and never actually saw 120hz.
If you have it set up right, there is a VERY noticeable difference between 120hz and 60hz. Yes, 1440p is nice too, but you can't just say that one is worthless and the other isn't; I personally bought and returned a VERY nice iiyama recently, because even though it was basically the best on the market, there were notable issues with it while gaming - if there were a 1440p TN panel that didn't have all the issues that IPS panels have (yes, I know TN panels have issues of their own, but those are unimportant for gaming), then I would buy it on day one, and use it for MMOs and, say, racing games, for which a 120Hz monitor isn't as helpful, but which you still want a decent response and minimal ghosting.
I would recommend for gamers to ignore this monitor and to buy a monitor with no on screen display and direct link DVI. This will get rid of all your latency woes for playing first person shooters. Not to mention these other monitors are available for a fraction of the price (screw aesthetics, I want performance). Clarity is a subjective issue, like they stated. I've NEVER had problems with small text on Windows 7 @ 1440p and I'm using a $200 Korean IPS panel (which you can order ones similar on newegg for $300 now)
For me, this is just another overpriced piece of equipment. Next.
Well, I know there have been QHD monitors for quite some time, but they're still expensive as hell and don't offer a better "gaming experience" IMO to justify them over FHD@120/144Hz. Until QHD comes in 120/144 Hz, they won't be on my "must have" list at all. Specially with the crappy as hell colors.
Cheers!
I got 15 minutes before work is over and I got nothing better to do but comment on something so boring that I forgot what I was going to say. So...
Happy Thanks Giving!
I'd wait for reviews of something like the Qnix QX2710 (PC only) with G-Sync or Viewsonic (one of the companies signed for G-Sync) VP2770 with G-Sync next year and not buy anything right now at all..
This seems to be impressive, well made 1440p monitor. Maybe not for fps-players, but I would love to play online RPG:s and other games with this. If they say that text is sharper than in competative panels, so will be gaming environment, even that it may be harder to see it.
Well made, product is well made. Sometimes it cost a little bit too much. I am not personally going to buy this, just because the price is too much for me, but in the other hand I am not buying Ferrari or even Mersedes Benz cars for the same reason...
Goog looking monitor, with exelent picture quality, what is wrong with that?
