Planing on building Gaming PC need help!
hrisiqk
14
Hello everyone Ive lurked in threads here in the past and Im sure there are intelignet and knowledgable people here who i can trust to help me in my plans.So for the past 10 years i've played on low end pc with rly low framerate in games and I finally have the chanse to build gaming configuration im posting here kuz i dont trust my country sites since when it comes to hardware most people tend to be the "trust me i know better" person,so i dont have any knowledge in hardware and especialy instaling it but ive chosen my parts and i need help i hope u can give a brother some schooling ^^
Heres the parts ive chosen
GPU -GIGABYTE GeForce GTX 1060 G1 Gaming 6GB GDDR5 192bit
CPU - Intel I7 4790(I was planinig on geting I5 6600K there is an option to I7 4790k ive red that skylake is better than haswell type but since im noob i wont overclock my parts and i dont know how and what vents do i need for processor without cooling)
Motherboard - im not sure which one from these 2 GIGABYTE GA-H110M-S2H or ASRock H110M-DGS they are both cheap in my country so thats why i want to pick them
Memory RAM - im considering one of those 3 Kingston 8GB DDR4 2133MHz, Kingston 8GB (2x4GB) DDR4 2133MHz or Kingston HyperX FURY 8GB DDR4 2133MHz
HDrive - i got some 1tb HDD not sure the specifics i think i will keep it,but i also want to buy 1 SSD thinking of ADATA SP550 2.5" 120GB SATA 3 or Samsung 650 EVO Basic 2.5" 120GB SATA3
I want to use it to store my games on it and I also want to ask if my windows shoud be on the SSD or keep it on HD
Powersuply - not sure how much wats do i need im thinkig of FSP Hyper 700W and i dont know of good PSUs
Case - i have no knowledge on good cases and how my setup would be installed im thinking for some nice case with some vents in it for lower temps - Segotep Polar Light , Deepcool Tesseract BF , Zalman Z1 Neo , Segotep Blade , Cooler Master Elite 430 RC-430-KWN those are cheap cases i can get.
Dont know how much fans do i need for case or do i need to replace cooling on cpu or gpu (i dont know what are the normal temp for loaded cpu or gpu work while playing so that would help me if u tell me so i can monitor it while playing)
I dont know anything about the instalation or placement of fans , air way , chasis or whatever those things are and how they work
I just started working in new place and this system will prob be rdy in 2-3 months hopefully ,so thats what im thinking i want to note that im mostly playing not demanding games such as cs1.6,WoW,LoL, i cant run Dota2 or CSGO atm but id like to play them aswell i also planing on playing farcry3(redo i played it on 10fps hard mode ^^)farcry4 and primal aswell and older titles like COD and such) so thats why im not geting cheaper or better cpu or gpu since those are on good price i dont mind if i run them on abit lower fps with this setup,im also looking forward to stick with dis rig for a long long time soo i dont know if any part cant sustain over time or suffer from overheating and i cant rly prevent that if i dont have the indept knowledge about the components and how they work also im planing on playing games in 1080p!
Thank you for your time and answers,feel free to suggest anything give me some explanation or whatever u can help me with for finaly building my dream gaming rig ^^
personally, i like this video card http://www.pazaruvaj.com/video-karti-c3142/evga/geforce-gtx-1060-sc-gaming-6gb-gddr5-192bit-pci-e-06g-p4-6163-kr-p343019822/
regarding the case, here is one of my favorite:
http://www.pazaruvaj.com/kutii-c3085/fractal-design/define-s-window-fd-ca-def-s-bk-w-p279051941/
And PSUs, any of the listed by you, will work perfectly fine.
i dont have a strict budget im puting most of my money into the cpu and gpu ive chosen the rest of the parts i stated are just cheaper and popular solutians that ive come across from the site i browse and i just put them here i dont know much about them apart from ive heard the hyperx memmory is pretty desent but im looking for bang4buck components for the rest of my build i avoid things like MSI xtreme gaming motherboards and such because the are probably overkill and i dont want to spend that much money on things other than gpu and cpu im sure there are cheaper and efficent solutions that can work good with gtx 1060 and i7 4790 i just dont have knowledege about the rest of the parts i can invest bit more money into them if im sure that they will last me long and they would be a way better choice but since im not planing on much high end gaming i think i can save money off them
your plan sounds solid.
While there are few things that can be changed, it will be wise to do the configuration really close to the build date due to new models, different prices etc.
So post here when you have the budget for the things you've listed and will see if there are better parts at that time.
personally, i'd go for the K CPU because basic overclocking is very easy and K CPUs are clocked higher than non K. for that, you'll need a Z170 MB.
also, the price difference for the 2400Mhz DDR4 kit is really small.
The PSU ... you are going to need 500-650watt CPU. which model depends on the pricing and availability in your county.
From "trust me, ..." sounds like you are from middle east - so both pricing and availability are very different from europe or us.
Would be helpful if you mention the country and may be even provide the link to some online store available there.
Im from Bulgaria the site im browsing is pazaruvaj.com the problem is its in bulgarian its basicly a site that shows me all the pc component companies in BG and i can pick the cheaper part avaliable but i also have to pick it from a trustworthy company since there are some that sell second hand or broken parts and i need to watchout for that so that kind of gives me abit lesser wide of choise i just checked the z170 and ive seen plenty of good gaming builds with it soo i can choose from
ASRock Z170A-X1/3.1
ASUS Z170-P D3
ASRock Z170 Pro4S
GIGABYTE GA-Z170-HD3 DDR3
ASRock Z170M Pro4S
the problem with the K cpu is that im scared kuz its without cooling and i dont know what coolers i need and how to set them up for proper air flow and stuff in the case plus i dont think i rly need OC since im sure that 4790 will be absolutely perfect for me i mean i got duocore e5200 or something atm id basicly jump in the clouds so thats why i gave up on the K cpus to save bit money i can put somewhere else ;P
as for x2400 memory stix how about
Corsair Vengeance LPX 8GB (2x4GB) DDR4 2400MHz
Corsair Vengeance LPX 8GB DDR4 2400MHz
Kingston HyperX FURY 8GB (2x4GB) DDR4 2400MHz
ive got 550wat PSU and im sure i need more power for this system since the cpu and gpu are from the latest gens and i want to be calm about it if i decide to run some demanding games
I went to money value convertor and i my planned budget is around 1000 US dolars the thing is that here in BG some parts are overpriced since we pay some kind of tax to the company as % i cant explain it proper soo u can give me suggesttions and i can check them out from that site what im mostly worried about is the components compatability and which case and how to setup a good cooling system for it so i can keep that rig for a long time ^^
Here is the PSU - any of those:
http://www.pazaruvaj.com/zahranvawi-blokove-c3158/corsair/rmx-series-650w-rm650x-cp-9020091-eu-p309239049/
http://www.pazaruvaj.com/zahranvawi-blokove-c3158/antec/high-current-gamer-hcg-850m-p156206643/
http://www.pazaruvaj.com/zahranvawi-blokove-c3158/seasonic/m12ii-620-ss-620gm-p41801216/
Memory:
any of the 2x4GB that is cheaper :) though if you are going for such a build - 2x8GB would be nice.
MB - GB is best of what you posted though i'd prefer:
http://www.pazaruvaj.com/dynni-platki-c3128/asus/z170-a-p295160919/
And for that, any of i5-6600K or i7-6700K
King ur build is good but its overkill for me i gues i'll shorten my budget to around 800$
i also reconsidered the cpu since i7 doesnt rly give me 2 much of value in gaming i think i'll go with i5 6500 or 6600 i want it stock with cooling fans since i wont bother OC so i gave up on the K skylake cpus
so the real question is which motherboard is compotable with i5 haswell and gtx 1060 about the PSUs do u think 620 or 650W is enough for such build i want to have like 100w above the req after the math so it wont overload or overheat or something xd also im sure 8g will be enough i have a friend whos playing dota2 and stream and his configuration is worse than this also 8gbs are enough for almost all games since im planing to play mostly older games.Btw thanks for ur time spent browsing xD
i5 or i7 are under 100watt, gtx 1060 is 120 watt, everything else is under 100watt together.
so you are looking at 320watt at peak load which you will never achieve while gaming. 600 is well suited for such system.
if you are going for non K CPU, then you don't need the more expensive Z170 MB.
If you are going for H110 or B150 MB - if the board comes with 2 memory slots, get 1 8GB stick, if it comes with 4 memory slots get the 2x4GB kit
this card looks scary to me super clocked with one fan XD,but what do i know about card design and heat resistance id prefer to stick with GB tho ,so the psu and case is left for consideration i like this one alot http://www.pazaruvaj.com/kutii-c3085/segotep/blade-p292524209/#opisanie altho the one u linked is triple the price of it has a ton of features from what ive red there,so it conciderable aswell!
Anyway im going to bed now thanks alot for ur time spent <3
Don't be afraid of that card.
It's not about the number of fans, but the whole cooler design. that card is awesome. It performs excellent within the same power and thermal limits :)
Also, EVGA is true top tier video card maker (unlike GB that is just "wanna be") and they have the best support and warranty service.
Enjoy your new build.
P.S.
you can see in my signature that i'm using older RM650 for more power hungry build that is overclocked to it's limits.
and with EVGA SC card.
