Approximate Purchase Date: Now
Budget Range: ~ $800 After Rebates
System Usage from Most to Least Important: (Media Server/File Server)
Parts Not Required: (Keyboard, Mouse, Monitor)
Preferred Website(s) for Parts: (amazon.in)
Country: India
Parts Preferences: None specifically. I am looking for a quality build.
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: I already have a monitor, for the one off situations, where I will need to administer the PC. 99.99% of the time, the PC won't need a monitor.
Additional Comments: I am looking to build a micro-atx desktop, that will sit inside a cabinet, and which I dont want to have to touch ever again - if I can help it. It needs to run 24x7x365, without a single squeak.
External powered and Unpowered HDDs (all WD - total 6) will be plugged in to its various USB ports.
This PC will be put on my network backbone (Cat6) , and serve all my devices for various purposes -
Sample usage scenarios: my work related backups from my office PC , my personal laptop has itunes library - but it will actually read the mp3 files off from a shared drive on this PC, my son and daughter would sometimes use the external drives (from android devices) and watch movies, or I might decide to connect to it from my bravia smart tv and watch movies or browse my photo albums.
There could be atleast 3-4 active & connected devices to this PC, getting served files in streaming mode.
I wanted to make this a budget build, but due to the fact, that I am a little skeptical of Intel's published policy to mark a CPU end of life - after 2-3 years, I left caution to the winds. In addition, I can't help but think - that I just may need some additional flexibility/extensibility in the future.
This is the list of parts I selected.
1) The Case:
Corsair Carbide Series SPEC-M2 MicroATX Gaming Case with Window Panel (No Power Supply) - CC-9011087-WW
Amazon Link: http://www.amazon.in/Corsair-Carbide-SPEC-M2-MicroATX-Gaming/dp/B017WL52YS?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A25RNQZGZ4W2DG
Manufacturer link: http://www.corsair.com/en-gb/carbide-series-spec-m2-microatx-gaming-case
2) Cooling:
The case above comes with a single 120 mm fan. And the case has space for 4 additional fans. Since the PC will be housed in am enclosed glass/wood cabinet (the only place I can hide it away!), I opted to go for the max amount of cooling possible by venting the case, and the cabinet where it will sit. I have already installed a 6" dia cabinet cooler fan running off AC mains for the glass/wood cabinet. So the job for the 4 additional fans will be to disperse hot air for this cabinet fan to process.
So I opted for a pair of these twin packs:
Corsair Air Series AF120 LED Quiet Edition High Airflow Fan Twin Pack - Blue (CO-9050016-BLED)
Amazon link: http://www.amazon.in/Corsair-AF120-Quiet-High-Airflow/dp/B00F6S10KK?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_2&smid=AYAZOP86CGXY9
Manufacturer link: http://www.corsair.com/en-gb/air-series-af120-led-blue-quiet-edition-high-airflow-120mm-fan-twin-pack
3) Power Supply
My decision was to go for a modular PSU due to cable management concerns. I believe also, that it is more spec than what my build really requires in current configuration. But since, I am investing quite a lot of money into this build, I would like to keep my options open for future extensibility such as adding graphics card or additional HDD or RAM in the future.
CORSAIR CXM series CX650M 650W 80 PLUS BRONZE Haswell Ready ATX12V & EPS12V Modular Power Supply
Amazon link: http://www.amazon.in/CORSAIR-CX650M-BRONZE-Haswell-Modular/dp/B01B72W1VA?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_3&smid=A2W54MYNIPYTO9
Manufacturer link: http://www.corsair.com/en-gb/cx-series-cx650m-650-watt-80-plus-bronze-certified-modular-atx-psu-uk
4) CPU
I was really on the lookout for a value for money processor, that was not about to reach end of life for next couple years. Given that in future I might use this PC for other purposes, I did not want the CPU to be a bottleneck. I checked both AMD and Intel and ultimately settled on the i3 7th gen platform as my choice.
Intel Core i3-7100 7th Gen LGA 1151 Processor
Amazon link: http://www.amazon.in/Intel-Core-i3-7100-1151-Processor/dp/B01NCESRJX?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_7&smid=A1AXQXLTPR366R
Manufacturer link: https://www.intel.in/content/www/in/en/products/processors/core/i3-processors/i3-7100.html?wapkw=core+i3+7100
5) Motherboard
This was an important decision factor - considering, that I was looking for 24x7 durability but affordable. The following product was advertised as such, and I chose it after considering Gigabyte and other Asus boards. An important consideration in this choice (aside from the form factor) was the chipset. I would have preferred Z270, but these were quite expensive, besides being made for gaming, which I do not require. The H270 boards are cheaper, but also lack certain features. The Q270 seemed mid-range.
ASUS Motherboard PRIME Q270M-C CSM
Amazon link: http://www.amazon.in/ASUS-Motherboard-PRIME-Q270M-C-CSM/dp/B01MR0H84F?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_6&smid=AYAZOP86CGXY9
Manufacturer link: https://www.asus.com/Motherboards/PRIME-Q270M-C/
6) Main memory
Since it's a file server, I did not want to go overboard on expensive memory. Then also, I did not find any ASUS certified DDR4 on amazon.
I have opted for a pair of these:
G.SKILL DDR4 2400MHZ AEGIS SERIES (4GB).
Amazon link:http://www.amazon.in/G-SKILL-DDR4-2400MHZ-AEGIS-4GB/dp/B01AIZUPW4?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_5&smid=AXPHJ4KBOYXKY
Manufacturer link: https://www.gskill.com/en/product/f4-2400c15s-4gis
7) Storage
While there will be external storage attached to the PC (via USB) - that would necessarily be for content, and not any OS. I wanted the PC to boot from an internal hard drive. The following was the most appropriate choice considering the price point.
Seagate New BarraCuda ST1000DM010 1TB 64MB Cache SATA 6.0Gb/s 3.5" Hard Drive Bare Desktop
Amazon link: http://www.amazon.in/Seagate-BarraCuda-ST1000DM010-Desktop-Latest/dp/B01LNJBA2I?_encoding=UTF8&psc=1&redirect=true&ref_=ox_sc_act_title_4&smid=AT95IG9ONZD7S
Manufacturer link: http://www.seagate.com/in/en/support/internal-hard-drives/desktop-hard-drives/barracuda-3-5/?sku=ST1000DM010#specs
Now some questions:
Question 1) Asus supports the 1151 socket, but does not list the i3-7100 amongst the list of supported CPUs (see list here: https://www.asus.com/Motherboards/PRIME-Q270M-C/HelpDesk_CPU/) Interestingly Intel says this motherboard is supported. (see list here http://processormatch.intel.com/MotherBoards/CompatibleBoards?componentName=i3-7100).
Who do I believe?
Question 2) I am of the view that my current usage will not require a graphics card (no monitor 99.99% of the time) Is this an okay assumption? Will it be okay (cooling/power limits) to go ahead and plug in a value for money graphics card later ?
Question 3) Most importantly - Will the above parts work together? Some of these parts are not returnable. and others are being routed from Amazon global in US with relatively longer ship times. Its possible I may find incompatibility after the assembly - so I want to be absolutely sure, that I dont have to return anything unless it's defective.
Deeply appreciate an early answer. Thanks in advance friends!
Country: India
Overclocking: No
1) The Case:
2) Cooling:
3) Power Supply
4) CPU
5) Motherboard
6) Main memory
7) Storage
Now some questions:
Who do I believe?
