Hello everyone,
I'm buying some new parts for my PC and would like to hear more knowledgeable people's opinions and suggestions whether or not they are a suitable fit for my setup. Pcpartpicker says they are all compatible with each other, but I want to know if I'm missing something since all the parts I'm buying cost around 1000€ all together.
Parts I already own:
GPU: RTX 3080 10GB
RAM: Kingston HyperX Fury RGB 2x16GB DDR4 3200
PSU: A modular Cooler Master 750W 80+ Platinum
Storage: 1TB M.2 SSD (May buy another one)
Parts I'm going to buy:
CPU: Intel Core i5-13600KF
CPU Cooler: be quiet! Pure Loop 360 Liquid cooler
MB: Asus PRIME B760-PLUS D4 ATX LGA1700
Chassis: Lian Li LANCOOL III ATX Mid Tower Case
The main reason I'm upgrading is my cooling & noise situation. I cannot even play moderately modded Skyrim without having the game sounds be drowned out by fan noise (just one example). Would this setup be adequate at cooling while also not the loudest? I am also looking for advice for managing air pressure inside the chassis. I am aiming for either neutral or slightly positive air pressure. The LANCOOL case has 3x120mm front fans and a 1x140mm rear fan. With a CPU cooler like the one I am going to buy, would I even need the rear fan & would having it running just result in negative air pressure? I am planning on mounting the AIO radiator on the roof of the case.
Final note, my choice of parts is partly a result of current availability where I live. Also apologies for spelling & grammatical errors, English is my second language.
GPU: RTX 3080 10GB
