Planning out desktop build and need some advice
saboughner89
25
so this will be my first system build ever and I have a couple of parameters that i need to follow.
- price needs to be in the ballpark of $1000
- needs to have firewire and enough usb ports because i will need it for audio recording and running DAWs
- i would like to be able to play recent games, graphics don't have to be maxed out, but i would like it to run them nice and pretty. (super sf4, splinter cell conviction, l4d2, ac2, mw2, perhaps far cry 2 or crysis)
- 2 hdd for dual booting, and esata for external backup
- preferably small-factor desktop (micro atx desktop) but not really too important.
- wireless pci card because im not sure where my computer will be in relation to a router.
- the 1000ish dollars needs to include a monitor (no need for speakers)
any advice, suggestions, or opinions would be greatly appreciated. at this point, i am not completely partial to either intel or amd, or nvidia or ati (only used intel and nvidia so far). at this point, anything is better than trying to game on my laptop with 2ghz core 2 duo, geforce 8400 gs, and 3gb ram (vista 32 bit).
hope this wasn't too vague, just need some guidance in the right direction, hope someone can help me out.
thanks guys,
scott
+1 for gkay09 recommendation.
and don't forget to buy the OS if you have to...people tend to forget including the OS to their budget.
BTW :
You don't need 2 HDDs for dual boot. 1 Big enough HDD separated into several partitions will do just fine.
saboughner89
25
i wanted to do a dual hdd dual boot so i could keep the OS's completely separate (win7 and linux) as well as their file systems. secondly that video card is pcie 2.1, not 2.0 that wont work will it? plus are there any low profile, 1 slot cards that would be good substitutes?
thanks so far guys
antisyzygy
245
4
Thats a tough budget for a build, let me try
Thermaltake LANBOX Lite VF6000BWS Black SECC Japanese steel Gaming Cube Computer Case
$78.49
2 X SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$109.98 ( THIS IS FOR 2 500 GB DRIVES !!! )
Hanns·G HH-241HPB Black 23.6" 5ms HDMI Widescreen LCD Monitor ( I have this monitor and its pretty nice)
$169.99
MSI R5770 Hawk Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
$179.99
COOLER MASTER Silent Pro 600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply
$109.99 ( QUIET PSU for AUDIO recording )
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
$109.99
ARCTIC COOLING ACALP64 Pro 92mm CPU Cooler
$11.99 ( QUIET CPU COOLER for AUDIO recording as the STOCK AMD CPU COOLER IS F^#@#@% LOUD!!! )
COMBO :
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGMBOX
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G HDMI Micro ATX AMD Motherboard
$234.98
Subtotal: $1,005.40:
If you can spare some extra cash go for a 5850 as it will perform MUCH MUCH better in the games you mentioned. For an audio build I wouldnt recommend changing the RAM or CPU but everything else is up for swapping at the recommendation of others. If you need Firewire that bad buy a 20-40 dollar firewire card. Some of the best hardware for Audio recording I have seen or used is USB anyway.
saboughner89
25
question, ive been looking up phenom 2 dual core and triple core cpus and some ppl have said you can unlock additional cores on the processor. is that possible? if not, i might just bite the bullet and go for a quad core right off the bat
saboughner89
25
since this is my first build, im thinking that i just want to go with the phenom 2 x4, but i might try overclocking slightly just to get a little more juice out of it
^ Hmm...
And as far as unlocking goes, it is not 100% sure that you can get a successful unlock...
I have unlocked a X2 550 to a Quad without any issues and without any need for additional voltage running at stock 3.1GHz...but it might not be the same in every case as I have seen people complaining about unstable cores even after voltage increase...
So if you really want to save money, then you have to take chances...I have seen more of hits than misses on this one but still you would never know...
saboughner89
25
alright, here is my rough build list:
Rosewill R101-P-BK 120mm Fan MicroATX Mid Tower Computer Case 24.99
GIGABYTE GA-785GMT-USB3 AM3 AMD 785G HDMI USB 3.0 Micro ATX AMD Motherboard 74.99
AMD Phenom II X4 925 Deneb 2.8GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Quad-Core Processor 145.00
ARCTIC COOLING ACALP64 Pro 92mm CPU Cooler 11.99
COOLER MASTER Silent Pro 600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply 109.99
POWERCOLOR AX5770 1GBD5-H Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1 x16 CrossFireX Support Video Card 149.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL 109.99
Western Digital Caviar Blue WD3200AAJS 320GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive 47.99
Western Digital Caviar Blue WD2500AAJS 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive 44.99
Rosewill RX25-AT-SC-BLK Aluminum & plastic 2.5" Black USB2.0 & eSATA External Enclosure 17.99
ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner 22.99
Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader w/ USB port / Extra silver face plate 14.99
ASUS USB-N13 IEEE 802.11b/g/n USB 2.0 Wireless Adapter Up to 300Mbps Wireless Data Rates 19.99
ASUS VH198T Black 19" 5ms Widescreen LED Backlight LCD Monitor 129.99
AZiO BTD-V201 USB 2.0 Micro Bluetooth Adapter (Class 1, V2.1 + EDR) 19.99
Rosewill RCM-3201V True 1.3 M Effective Pixels USB WebCam 24.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders 99.99
this is in the ballpark of 10-11 hundred all through newegg.com. im open to any suggestions to different components and whatnot for better performance or to save some more cash.
also, would anyone suggest installing noise reduction foam in the case and what product?
jbakerlent
2,290
109
I agree with gkay, if you are going to dip down to a 2.8GHz CPU, I would save $45 and drop down to an Athlon II.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
Then for the HSF
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341016&cm_re=ocz_modxstream_pro-_-17-341-016-_-Product
saboughner89
25
alright, i might just go with an athlon 2 x4 at 2.9ghz, but that heatsink says it fits intel sockets (unless it really doesn't matter). how are the hdd and psu in terms of noise because i want as little as possible for recording.
^ check in the specs properly...
Compatibility Intel: Socket LGA1366 / 1156 / 775
AMD: Socket AM3 / AM2 / AM2+
And is cheaper with Free Shipping @amazon
http://www.amazon.com/Cooler-Master-RR-B10-212P-G1-Universal-Heat-Pipe/dp/B002G1YPH0/ref=sr_1_fkmr0_3?ie=UTF8&qid=1273031940&sr=8-3-fkmr0
And the PSU, get this one instead of that...Comes to same price after shipping and IMO this is slightly better...
OCZ Fatal1ty OCZ550FTY 550W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
As for the noise,
the HDD is a single platter design so it wont have much moving parts and hence less noise as for the PSU, I have not seen any complaints of it being noisy either...
And if you want to reduce the noise, then you should be looking for a slightly better case...
saboughner89
25
heres my revised list:
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G HDMI Micro ATX AMD Motherboard 89.99
AMD Athlon II X4 635 Propus 2.9GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core
Desktop Processor 105.99
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-
212P-G1 120mm "heatpipe direct contact" Long life sleeve CPU Cooler 29.99
Scythe GentleTyphoon D1225C12B4AP-14 120mm Case Fan 17.99
Scythe S-FLEX SFF80B 80mm Case Fan 11.99
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified
Modular Active PFC Power Supply 69.99
Western Digital AV-GP WD5000AVDS 500GB 32MB Cache SATA 3.0Gb/s 3.5" Internal
Hard Drive -Bare Drive 54.99
Enclosure 17.99
Data Rates 19.99
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen 16:9 Full HD 1080P LCD Monitor
300 cd/m2 1000:1 (ASCR 12000 : 1) Built in Speakers 169.99
i think ill wait on sound reduction stuff until after i actually build the damn thing. should cost me in the ballpark of 11-1200 bucks. anymore suggestions are welcome :D
^ Same question...Why still stick with those WDs when the Samsung F3 offers better performance and comparitively less noise...
And again I would suggest a better case...you are spending about $55 for a low quality case and additional case fans...rather get a better quality case...
Similar threads
