Planning to built home pc.
raheemmalik
Commendable
Sep 17, 2016
55
Sir I am planning to assemble a personal computer for home use So can you please tell me whether I can go with described specifications or any other. My budget is around 20k-30k inr.
Circle Gaming Cabinet CC 821 without SMPS (with 3 LED FAN)
Intel Core i3-6100 6th Gen LGA 1151 Processor
Gigabyte GA-H110M-S2 DDR4 Intel 6th Generation Motherboard LGA 1151/ Intel H110
Iball Marathon - 500W Peak power supply (SMPS).
Seagate Barracuda 1TB Desktop SATA Internal Hard Drive
8GB DDR4 Kingston HyperX Fury Black Series 2133 MHz DDR4 CL14 288 Pin-DIMM Memory - HX421C14FB/8
Gigabyte Nvidia GT 710 2GB DDR3 (GV-N710D3-2GL) Graphic Card / PCI-E 2.0 / 2GB / DDR3 / 64 Bit / D-SUB/Dual-Link DVI-D/HDMI / Low Profile / Single FAN.
or smps Corsair CX430. or suggest me any other
sorry if I've done any mistakes unintentionally.
Thank you.
THANKS FOR YOUR FAST REPLY
what about the other components do they would fit perfectly?
