Plasma TV Not won't turn on (LG 50pn4500)
Salair456
47
I've already tried most of the basic things like using another outlet, I've unplugged it and let it sit for a while before trying to turn it on again and i made sure im not using a power brick to plug it in. I've opened the back of the TV and I don't see any blown capacitors on the board where the psu is connected nor are there any blown capacitors at any other boards in the TV. I've checked for faulty connections in the main board but i dont see anything that looks suspicious, then again, i don't have too much experience when it comes to looking for those kinds of errors. I do have some soldering experience so if i need to solder or resolder something safely that won't be a problem, it's just that I cant really figure out what the problem really is. My warranty has expired by the way so returning it is not an option. I can post pictures of the main board if needed too. Thanks for the help and i appreciate your time.
the red power light is on. i think that's the standby light. im not too sure what the fuse is but i will google it
Okay, I believe that i have found the fuses now what should i do from here?
http://postimg.org/image/kp32ybevv/
http://postimg.org/image/93gjv1gkb/
http://postimg.org/image/tf21s74m3/
- These are the pictures of the fuses i have found. Do they look fine? How can i know if they're fine or not?
Sorry about the ridiculously long response time. I have obtained a multimeter to test the fuses and yeah, the fuses are fine. Currently im checking the capacitors on the powerboard to see if any of them may be the issue. Thanks again for the help.
