Playing games 3 days ago were fine now it's major fps drop and 99% GPU and CPU usage.
swagpies22
19
Hi thanks for taking the time to read so yeah I have a pretty big problem I have no idea what it is.
So 3 days ago I was playing some Overwatch and I have my fps locked at 100 and it has no trouble. Same with League Of Legends it ran fine and at a decent CPU and GPU usage around 50% or less at high settings. Well today I came to play some games and my pc's fine, just when I run any game it's badddd. When I went to play Overwatch the first thing I saw was that my game quality dropped.
So I go to put turn it back up to where I usually have it meanwhile I noticed my fps dropped from the usual 100 fps to struggling 9 fps. I got to my task manager to see whats going on and my GPU and CPU are running at 99% Which the only things that were running were Overwatch and the Overwatch launcher and the task manager.
(Update) I just tried again and my Overwatch was fine at the 100fps+ 10 seconds later it dropped to 40fps now its going from 30 to 40 fps....Now my CPU and GPU are also at 80%.
Maybe it has something to do with my MSI software's? Or should I do some full scan on my pc?
My PC specs
CPU- Intel i3 7100
GPU- Geforce GTX 1050Ti
Ram- G.Skill 8GB
Hard drive- WD-Blue 1TB
Operating system- Windows 10 Pro
Ask away pls.
Whats going on here doesn't make much sense, unless you literally unplugged your monitor from your GPU and plugged it into the onboard graphics.
I would download DDU and kill your video drivers and reinstall them first.
Nope just task manager, Google chrome and some provider host. Well also to say I think my pc has been acting weird since a Windows 10 Update ....Like some running stuff in the background and also the February update crashed my moms pc and had to get it fixed. So maybe it's a bug with the update.
Nope only games my pc is fine it's just when I play any game the fps ranges from 20-40 fps.
Im going to run some scans and im going to re plug in some GPU stuff thats what one of my freinds said. So I hope something works.
XD I literally just unplugged my montor from my motherboard and plugged it in on to my GPU and it works fine now lol. Well now atleast I got myself to majorly clean my pc. Well thanks for the susgestion!
Yeah that will do it.....
