Playing GTAV PC with my specs, help please?
shahzeab
4
I have a custom made pc which has the following specs:
4GB RAM
Intel Pentium Dual Core G630
Asus AMD Radeon R7 250X (2GB, GDDR5, PCI Express 3.0)
will i be able to run GTA V on any settings possible? im confident about running it however i think my processor is the main problem, please can someone let me know if i can run it because i dont want to buy the game unless i can run it good.
Your CPU is going to be a major bottleneck here as the game is quite CPU intensive, though a patch was released recently to reduce CPU usage so the bottleneck is reduced. Honestly, you should be able to run the game at 1080p on low settings 30FPS if you're lucky, the game may not run at all.
