[SOLVED] Playing music from an RCA output CD player on a 5.1 surround system ?
edikecske
19
Hello, I recently bought a Sony DE475 surround receiver with a set of speakers. I want to buy a CD player to play my music CDs on it, but most of the older players only has RCA stereo output, rarely Toslink. If I connect it to the CD stereo / Toslink input on my receiver, can I change the settings on it to play the music on all speakers? Sorry if it is a dumb question, I am new into this.
Thanks in advance! :)
I went through the receiver's specs and it has Dolby Digital, DTS, and Dolby Pro Logic decoding, and also has an A.F.D. mode that I can turn on. I do not know much about these things, would it work?
I already did that, the receiver is not able to convert the stereo signal into surround.
There is no surround info in a stereo signal, and "5.1 decoder" will not help - these devices usually accept digital signal (SPDIF), and convert it to five-plus-one analogue signals.
Check your receiver' audio settings - there should be a way to make it play your stereo signal on all channels.
I already did that, the receiver is not able to convert the stereo signal into surround. My plan is to buy a 5.1 decoder, plug my PC and CD player into it, and then connect the decoder’s multi channel output to my receiver.
If a piece of music is recorded in stereo, making it play on all the speakers would pretty much ruin the intended sound the producer and artist intended you to hear. Unless you are just there for the wall of sound, then I guess it does not matter much.
that depends on your playback equipment, if your speaker placement is correct, than its about same as hearing it from headphones + you get vibrations which headphones lacks 🙂
that depends on your playback equipment, if your speaker placement is correct, than its about same as hearing it from headphones + you get vibrations which headphones lacks :)
You are going to get front L/R signal coming in from the rear, it may not be noticeable but I don't know of any audiophile setup that uses surround speakers for imaging when playing stereo sources. It's just not worth it for proper sound to force a stereo mix into 4 speakers aside from getting a simple "wall of sound". You need something actually mixed in surround sound to want to have rear speakers working, it's really not an issue when they don't, unless they should be working like in a movie.
