Pleas help my with this build.
A few things actually:
- You're getting a Kaby Lake CPU with a SkyLake MOBO, therefore that MOBO needs to have been updated to support natively the newer CPU, otherwise it won't POST(work). Make sure it has been updated beforehand and you're good to go, or get a Kaby Lake mobo like a B250 and don't worry about it.
- 320GB of HDD is very very veeeery little. You will fill it up in no time if you wish to install some games on it. I'd recommend getting at least a 500GB or 1TB HDD.
- That PSU is fairly bad, if you wanna keep low cost and still get a decent piece, search out for a CX450M ( with gray label ) or a SeaSonic S12 520W.
I will contact the seller of the motherboard on updating the bios before shipping it to me, and i will probably only play csgo and rainbow six siege on this computer, do i still need a 500gb HDD?
Is the psu really important because i got a strict budget of 450 euro, and i also have to buy rainbow six ( i already got csgo)
Dont just ask the vendor if it has the newest bios, this is very easy for them to lie and just go "umm yea". Ask them if they know what version of bios it ships with. And you can look up which is the newest version on the board OEMs website.
