Okay I'll try to keep this short and sweet! I'm looking for better performance in and out of games, bf3 doesnt run so hot which to me is suggesting an upgrade is in need. I need opinions on whether to just get a better GFX card, or a new build. Not just for the now, but for the future as well!
CURRENT RIG:
CPU: Q9950 OC'd @ 3.4ghz
MOBO: Asus Rampage Formula
PSU: PCP&C 750W
RAM: 8GB DDR2 800
GFX: ATI HD4870x2 (Dual core, not 2 cards)
CASE: Coolmaster HAF 932
HDD: 300GB raptor
The rest of my setup is pretty much irrelevant at this point. My question is, can I throw in a GTX580 and be good with this setup for quite some time, or should I should I honestly just fork out the cash for a new build. Again, I'm looking for the best bang for my buck in the sense of longevity, not performance. If I need to spend the money to get what I want, then I will.
POSSIBLE NEW BUILD:
CPU: i7-2600K (air cooled = plenty?)
MOBO: ASRock Z68 Extreme7 Gen3
PSU: Might use current unless GFX card choice needs more, suggestions?
RAM: 8GB Mushkin Blackline DDR3 1600
GFX: Either GTX580 for now, possible SLI down the road OR a GTX590. Suggestions here? Which will give me the longest ride/bang for the buck?
SSD: Considering one, but reading some dodgy reviews is scaring me off a bit
Any help or suggestions is greatly appreciated! Any better parts for the money or reliability suggested will definitely hold some weight to my decision. Will my current rig with a new card do well for some time, or should I just throw together a new rig?!
Thanks again!
CURRENT RIG:
PSU: PCP&C 750W
RAM: 8GB DDR2 800
HDD: 300GB raptor
POSSIBLE NEW BUILD:
Thanks again!
