Question PLEASE CHECK FOR COMPATIBILITY
Jul 18, 2019
4
ryzen 5 3600
gigabyte b450 DS3H
zotc rtx 2060
anmy genric atx case
corsair vs650 psu
LPX vengence 8gb 3000 Mhz
kingston a400 ssd
coolermaster masterair ma610p
Jul 14, 2019
62
1.) Just so you're aware (In case you aren't), your mobo is Micro - ATX, you might want a Micro ATX tower. It'll be cheaper than a mid tower ATX and it won't look as silly as a little board inside a big ATX lol.
2.) Your CPU is 3rd Gen Ryzen chip. Your mobo only supports up to 2nd gen.
3.) If you're sticking with the Mobo, manually reduce the speed to 2933mhz.
Other then that, you're good to go. Look at your measurements and double check. 👍
Awful psu choice, it’s not the worst but is is poor quality. Is the RAM 2x4gb or 1x8gb? Ideally you want 2x8gb (16gb) these days for gaming and it is best to buy it now, if planning on 1x8gb now and 1x8gb later this can cause compatibility issues.
Jul 18, 2019
4
ILL MAKE SURE TO GET A M-ATX CASE
Reactions: aarono123
Jul 18, 2019
4
WHAT ARE YOUR THOUGHTS ABOUT THE COOLER MASTER MASTERWATT 650W?
IT IS 1X8GB BUT I PLAN TO EXPAND LATER
