Hi, I'm building my first pc and think that everything checks out ok, I just want to make sure I haven't made some massive n00b error in choosing my components, if you could check it over and suggest any necessary changes I would be grateful.
Also, I'm struggling with a monitor, I can't find any 1440p 144hz or 120hz monitor for less than £560, is this right? If so is gtx 980 sli overkill for 1080p gaming? I don't want to get a 4k monitor because of the low refresh rates.
Thank you for any help, the specs are as follows
Intel Core i7-4790K 4.0GHz Quad-Core Processor
£255.54
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
£26.34
Asus Z97-A ATX LGA1150 Motherboard
£110.24
Corsair Vengeance Pro 16GB (2 x 8GB) DDR3-1866 Memory
£106.39
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
£53.94
£53.94
EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 Video Card (2-Way SLI)
£461.94
£461.94
Corsair 750D ATX Full Tower Case
£119.98
EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
£63.31
Pioneer BDR-209DBK Blu-Ray/DVD/CD Writer
£58.74
Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)
£67.95
Just to clarify I'm really unsure about which monitor to get and want to make sure the pc build is good enough to run new games at high settings for a while to come.
Thanks.
£255.54
£26.34
£110.24
£106.39
£53.94
£53.94
£461.94
£461.94
£119.98
£63.31
£58.74
£67.95
Thanks.
