Please connect PCie power cables issue.
Oct 16, 2018
5
ive got a palit 1080 jet stream and a Corsair VS550 550W Bronze Rated PSU... ive plugged both the 8 pin and six pin connectors in both on their own and then together and every time the rgb and fans come on the graphics card but says i need to connect pcie power connectors for this gpu on the screen?
PCPartpicker is a very good reference in terms of compatibility. Is the 1080 a new addition to your system? If so, what did it replace? It is possible that the PCI/E cables from the PSU are defective, or the PSU itself might not be working as it should. It is even possible that the PCI/E slot on your motherboard is defective. Do you have another PCI/E slot to install the GPU in to test it out?
Welcome to Tom's!
How old is your PSU? The VS series of PSU is not one of Corsair's better units.
not sure exactly how old but that is the exact model number.. i bought it part of a custom pre built system about a year ago
yes the 1080 is a new edition to my build and its replacing an EVGA 1060 6gb mini using the same slot and pci/e cables etc plus ive tried using the adaptor cable that came with the gpu.. im using a z270 k3 mobo would it be ok to use the slot thats (labled crossfire) be ok to try it on? i had no probelms with the 1060 im only replacing it because of how hot it runs
Should be ok to test your card in the other slot, just to eliminate a problem with the GPU.
ive actually tried just taking it out and putting it back in and found another pci/e and ive booted into windows. but it isnt showing in task manager? or do i have to wipie my old display drivers and updating etc then it should register the card right?
