I'm, planning a new build with an E2160 processor.
I understand that it runs at a default FSB of 200 and multiplier of 9. Therefore 200x9=1800MHz
Now if I overclock that FSB to 333 I get ~3000MHz (2997MHz exactly).
I know that overclocking the FSB will increase the RAM speed as well on Intel chipset motherboards.
Am I right in thinking that with that 333FSB, my RAM will be running at ddr2 666 speed?
To take a step backwards right now, if running at the default FSB of 200, this means my ram will be running at ddr2 400 speeds? But say I have ddr2 800 RAM. So I set the RAM to 800 in the BIOS settings, is it running at 800 even though my FSB is only 200? I get this is called "asynchronous" timing, when the the FSB and RAM speeds don't match.
The main reason I guess I'm confused is that all the overclocking guides I've read mention that you should set your RAM speed down low when upping the FSB, so as not to push the RAM too hard in the early stages, because the FSB and RAM speeds are linked.
But why does this matter if I can just set my ddr2 800 to 800 in the BIOS, and gradually up my FSB to 333? Won't my memory just stay at 800?
?Please Help. ***Very Confused***?
