I am a super newbie and need your advice on what's the best way to hook up my monitor to my computer. I have a Samsung T260HD
my new computer will have graphic card ATI 5770. What is the best way to hook this up for use with Office suites, spreadsheets, documents, etc? The main function will be for work, occasionally I might watch a movie. It came with 2 cables white with screws and the other one is blue with screws. I guess the blue one is VGA not sure what the white ones are I think D-Sub cable? What cables do I need to buy to get the best resolution from this monitor and graphic card? Please use layman terms as I am tech illiterate, I would appreciate any help at all. Also I'm using very nice Klipsch ProMedia 2.1 THX Certified, for the sound......
TNA
TNA
