Hi all, I need some advice on what will be the best way to upgrade. My son recently accomplished some of the goals that were set earlier, and as a result of our promise, I am getting him a new gaming PC. However, my last build was around 2021ish, and it's been a while since I've understood what is going on. Below are both my setup and my son's setup. I am looking to see what makes sense, whether to upgrade parts or buy new. I work from home and don't really need everything maxed out in terms of gaming. However, my son is targeting 244 fps at 1080p, and his monitor supports it.
My current PC for work/gaming:
CPU: 5600X
GPU: RTX 3080 12gb
DDR4 32gb
Playing at ultrawide 1440p (3440x1440)
Games: Division 2, FarCry, Age of Empires DE
My son's PC:
CPU: i5 12400
GPU: RTX 2080
DDR4 16gb
Playing at 1080p with a monitor supporting 244fps,
Games - warzone, fornite
Option 1: Build a new gaming PC with a budget of up to $1,800. Going for the Ryzen 7800X3D with RTX 4070 Ti Super and DDR5 32gb.
Option 2: Upgrade his current PC with an i5-13600K and RTX 4070 Ti Super. He currently has an MSI PRO B660-A D4 ATX motherboard.
Option 3: Upgrade my PC with a 5800X3D and RTX 4070 Ti Super, then give him this upgraded PC. I will then take his PC and keep my RTX 3080 12gb.
Thanks!
CPU: 5600X
GPU: RTX 3080 12gb
DDR4 32gb
My son's PC:
CPU: i5 12400
GPU: RTX 2080
DDR4 16gb
Thanks!
