G
Guest
Guest
Ok I got a quad core Q6600 intel , XFX 680i sli LT motherboard, 2gig of ram DDR2 pc6400 , 250 hd 7200rpm , 600w pws, XP home 32bit and a Gforce 8600gt 512 pci express.
Ok the only thing i do on this PC, I do my regular email and go online and shop but over all i play Flight simulator X this game can kill any card out there if you put it max setting i heard that the gtx280 had issues handling this game in frame rate per sec . So what i want to do is to upgrade to vista 64 and put 4gigs of OCZ sli high pro ram and dual 9800gt . But can my motherboard support the 9800gt ddr3 pci express 2.0 ??? what do you recommend without buying another motherboard . Oh i forgot my 8600gt gives me 30 frame rates per sec but when i fly near a city it goes to 8 frame rates per sec on med high setting anything lower the grafics is horrible .
