[SOLVED] Please Help - Air Cooler
JasonJJJ
115
Hi All,
My new computer is here: https://pcpartpicker.com/user/PartPicker2017/saved/pWfyWZ
I've run into a problem where if I use a Noctua NH-D15, there won't be enough clearance for G.Skill Trident Z RAM since my case (Corsair 460X) is a compact mid-sized case.
I don't believe I'll be overclocking the i7-12700K (or very little if at all). Can you please help me decide what to do in this situation?
  • Option 1: buy low profile RAM and keep the NH-D15 (will be a tight fit but i think it will work)
  • Option 2: keep the ram and get a smaller NH-D15s
  • Option 3: keep the ram and get a Noctua NH-U12A
Is the D15s or the U12A better?
Thanks in advance for your help!
Would the D15s just be a better solution?
No. If you already got it, just move the fans back.
iu
I have a similar setup and use the NH-D15 with this low profile memory:
https://pcpartpicker.com/product/W6...2-x-16-gb-ddr4-3200-memory-cmk32gx4m2e3200c16
and then I just put the second fan directly above sitting on top of the memory heatsink. Works fine for me, maybe worth considering.
