So I'm trying to play battlefield hardline but I keep getting fps drops after 2 mins for no apparent reason I go from 60+ down to 20 and it stays like that for the whole game it goes up and down which makes the game unplayable I was getting steady and high frames in the beta? But ever since that march 3rd patch on battlefield 4 (must have applied the patch to bfh) I have been getting these frame drops, I went onto a live chat with ea and they said it was a connectivity issue which I didn't think it was anyway they didn't fix my problem. . If anyone could help or even tell me if you have the same problem it would be much appreciated thanks.
Basic specs:
Amd phenom ii x4 955 OC 3.7ghz
8gb ram
Sapphire radeon r9 270x
(If you need more info just ask)
Basic specs:
8gb ram
