Please help build my next gm
Chicago_RMX
7
Hi,
Currently leaning towards OriginPC's Millennium purely based on user reviews. Preferably using the link below or a comparable reputable site, please build me a gaming rig that comes as close to meeting my criteria below, listed in order of most important to me to least important, all for under $3,300
https://www.originpc.com/configurator/prime/1.aspx?shellid=2
  • ■ Budget around $3,300
    ■ Current AAA games w/ Ultra settings @ 60 fps
    ■ High settings @ 60 FPS for any game for the next 4 years with zero upgrades.
    ■ Ultra settings @ 60 fps for 95% of AAA games for the next 5 years based on reasonable upgrades.
    ■ Quite enough where my GF could sleep on the couch 5 feet away.
    ■ Able to handle three monitors - NOT 4K
    ■ Jaw dropping graphical improvement over all future PS4 games.
    ■ Finally, I do not want to pay for anything that does not noticeably improve or enhance my gaming experience.
    There you have it. Please help post your recommended customized config from OriginPC or elsewhere with Pricing.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($374.95 @ SuperBiiz)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler ($92.87 @ Amazon)
Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3 Motherboard ($304.99 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 32GB (4 x 8GB) DDR4-2400 Memory ($199.99 @ Newegg)
Storage: Samsung 850 Pro Series 512GB 2.5" Solid State Drive ($229.98 @ Amazon)
Storage: Seagate 2TB 3.5" 7200RPM Hybrid Internal Hard Drive ($91.99 @ SuperBiiz)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (2-Way SLI) ($667.99 @ SuperBiiz)
Case: Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case ($110.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA P2 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply ($227.99 @ NCIX US)
Operating System: Microsoft Windows 10 Pro OEM (64-bit) ($134.99 @ SuperBiiz)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter ($24.99 @ SuperBiiz)
Total: $3359.69
Generated by PCPartPicker 2015-10-01 04:01 EDT-0400
Don't get the wrong idea. But after building a System from OriginPC, it seems like they are just Over Expensive. You have to pay 500-1000 more than buying them individually from Local Shop.
This is fantastic, thank YOU! I tried building something similar to this and the rate at which the $$$ started to climb made my head spin. My only question is will I need the additional 980 TI today to meet my needs or can I purchase the additional video card next year?
I think Rabab may have weent a little overboard. For starters I would not go with the 5820K. Consider going with the skylake 6700k The extra threads are not but not utilized in games all the often howevever the higher clockspeeds with do far more. This also means getting a Z170 MOBO. 2x512 SSD is too much. 1 is plenty. 1 980 Ti is going to be plenty for 60 fps for some time even at 1440p.
I just squeezed everything in that price range,so that he can get the idea how much he is losing if he set to build a System from OriginPC.
Besides this build is for those you plan to be a Youtubers & do a lot of Gaming at 21:9 1440p or 4K.
For a Starter build guide your suggestion is much more appreciated.
For three 1440p monitor you need 2 GTX 980Ti to handle the modern games effectively.
But for three 1080p monitor a single GTX 980Ti can able to handle that.
