Hey all.
So, I recently built a pc and i've been trying to fix my "Antec Kuhler h20 920" water cooler, it cools fine but the software won't work so I have no control over the temps/fan speeds...Antec think the software won't work because the usb header cable is faulty, so i'm having a new one sent to me by Antec soon so until then i'd like to set the fan to 100%; does anyone know the best way to do this? if I take the cable out it goes to 100% but the light doesnt stay on, so is water actually cooling my CPU? the temp is at 28-30 degrees celsius doing nothing on my desktop but it's silent so I have no way to know if its actually working 🙁
Also, "smart fan control" off in the bios doesnt turn ANY of my fans to 100% like it should do and i'd also like to control my case fans with software like Speedfan, but no matter what I do my case fans won't go higher than 620RPM (they both have a max of 2000RPM). I've tried loads of different software and changing the settings in the BIOS.
Would really appreciate any help as its driving me mad!
