Please help!! Connecting pci 6 pin connector to molex connector?
jerrie86
123
There are only two 15 pin sata power connectors coming from PSU ( used for SSD and HDD) and two 6 pin PCI express.
ANd molex connector has only two pins to it? is is 2 pin molex connector?
Sorry for noob question. 😛
I have the short-term solution for you.
1) Buy one Athena Power Model CABLE-S15S15M4 http://www.newegg.com/Product/Product.aspx?Item=N82E16812198027
2) Then use one of your 15 pin sata power connector plug into this adapter, now you have one 15 pin sata power connector for DVD or HDD and one 4pin power connector for Drive Bay Fan.
And the long-term solution, you may look for PSU on sale this year BF.
Thanks man.Appreciate it. Will buy it and let you know how it goes.
Also, will look out for PSU this BF. Thanks Again.
Wanted to let you know that it worked great. THanks!!
