Please Help Crossfire help
dschmidt04
Hello all this is my first time asking a question on Tom's, so please bare with me. First off, This is my set up:
Asus M4A88T-V Evo/ USB3 motherboard
AMD Phenom II x4 955 BE
16 GB Corsair Vengeance PC12800 DDR3 RAM - 1600MHz
Corsair TX850W Power Supply
2 x XFX HD-687A-ZHFC Radeon HD 6870 900M Video Card
Corsair Carbide 400R Mid Tower
Second, This mother board only runs crossfire x16 x4 and that is no good.
What do you recommend as far as a Crossfire motherboard with these two cards? I am willing to buy new motherboard and processor so feel free to recommend a few. I would like to stay under $400 for the pair (will spend more if worth it) and maybe throw some new RAM in there too. Please help. I would like to get the best deal, as far as performance goes, with my 2 6870's. If you need any other information, please ask.
I have the ASUS Sabertooth 990FX ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736 ) and have had no trouble with it.
However, if your looking to improve performance you might consider going with a Sandy bridge setup. You could easily fit that into your $400 budget.
Intel Core i5-2500K Sandy Bridge 3.3GHz ( http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072 ) ~ $230
ASUS Maximus IV Gene-Z/GEN3 ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813131806 ) ~ $180
Total ~ $410
This would be my pick. It only does dual PCIe at X8,X8, however, there is very little difference ( around 1-2% ) between X8,X8 and X16,X16.
Here's a slightly less expensive MOBO that would perform similarly if you really want to keep your budget under $400.
GIGABYTE GA-Z68MX-UD2H-B3 ( http://www.newegg.com/Product/Product.aspx?Item=N82E16813128503 ) ~ $160
