Please Help DRIVER.POWER.STATE.FAILURE Blue screen
Billyharvey93
5
Hi i have a week old dell inspiron 5748 laptop and it keeps going into blue screen saying driver power state failure but only when its not plugged into the power supply could anybody help fix this issue ?
On Thu 06/11/2014 01:16:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110614-16390-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x14F1A0)
Bugcheck code: 0x9F (0x3, 0xFFFFE000085E5060, 0xFFFFD001A5F6B960, 0xFFFFE0000C589AA0)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Just found a program to check the mini dumps and this came up can anyone explain how to fix this ?
Thanks Bill
