Hi I’m building a PC and I’ve run into so many problems with this case and cables management.
I cannot fit all these cables into my case and close the metal shield and glass panel, please help. I have a bunch of extra stuff too that is just taking space. I also don’t have any space between hard drive bay and PSU. I need to use the HD bay. Please give me some tips or advice, I’ve been spending a week on this.
Case: Cooler Master Masterbox MB530P
(has a cable shield on the left side and glass panel back.)
Motherboard: Maximus XII Hero
AIO: NXZT Kraken Z63 (front mounted)
Fans: 6 Aer RGB 2 (3 front, 2 top, 1 rear)
2 140mm fans that comes Radiator
NZXT: RGB & Fan controller
NZXT: Internal USB 2.0 hub (under controller)
PSU: Corsair HX850i slot used (2 PCIe, 2 Sata, Corsair Link mini USB, 24 pin, 8 pin EPS and 4 pin EPS)
CableMod: Replacement Power Cables (help a bit)
Asiahorse: Extension cable (tried it first but switch to CableMod for shorter length!
Update: I managed to get it done today. My first method is to move the Fans & RGN controller to the front and the USB hub toward the back next to PSU. I used the Cablemod power cables to get rid of the extensions. I sent all the cables toward the deeper back of the case where the two hubs previous sat! Managed to screw down the metal panel with maybe a 5-10 mm bulge. I’m able to put the glass back on but I didn’t tighten the screws all the way just so not to put pressure on the glass!
View: https://imgur.com/a/RZYQT8T
