I have just recently built a Pentium 4-based rig for older games, but I am experiencing a problem. Here are my current specifications.
ASUS P5WD2 Motherboard
Pentium 4 530 HT @ 3.0 GHz
2 GB DDR2 PC5300 hynix RAM module
GeForce 7950 GT 512 MB PCIe
PSU Delta 400 Watt, 16a on 12v1 and 12v2 individually
My problem is this. Whenever I tried to run WolfQuest 2.7.1, as soon as it starts to load the game after creating my wolf, the whole system freezes, and the audio is stuck. Now I know my system doesn't meet the game requirements but hear me out. (Note: Tried it on the lowest settings possible)
I also tried the older version, 2.5.1, which ran perfectly fine... Until I turned the resolution up to 1440 x 900, and at one point in the game, the whole system froze again. And my system definitely meets the requirements for this game. (Note: Played on maximum settings.)
My question is this. Could it be that the PSU is not supplying enough power for the GPU? I've read it requires a MINIMUM of 18a on the 12v rail, but really I should have somewhere between 20-24. But both of the 12v rails on my current PSU are rated at 16a. Do you think the PSU is the problem? Have you experienced this before?
When I ran Prime95 and FurMark separately, it's never happened. I haven't tried them together at the same time however. I may try to recreate the problem.
Please reply soon, thank you.
P.S. Please don't mix up the GeForce 7950 GT with the Radeon 7950 HD, totally different cards, massive difference in age.
P.P.S. No the components are not overheating, I've monitored both the CPU and the GPU and the temperatures are fine.
