Hi, I have built a new PC - Gigabyte Z790, Gigabyte 3070, 13900, Windows 11. Its been impossible to get the machine to install Windows 11. I am not a complete novice having built a couple of Windows 10 PCs using Gigabyte motherboards before, but nothing has prepared me for the mass of continual problems.
I have been through many many youtube videos and online advice - tweaking setting such as TPM2.0, secure boot, CSM etc. I've tried every permutation and the system just got as far as "Windows 11 not compatible with this PC". I have literally tried everything I could find online.
I then found some advice which suggested to update Product Factory Key in one of the settings (sorry can't remember the precise name). I did this and now I get no display, can't access the Gigabyte bios, and the fans on the 3070 have stopped spinning.
The symptoms are:
* PC will turn on, fans full speed, then settle down
* Graphics card light on, fans activate and then die
* Orange "VGA" light on motherboard (VGA/CPU/BOOT/RAM lights)
* No display at all - was expecting to see the BIOS set up screen.
I've done the battery out and shorting of the pins to clear the CMOS, but still nothing. I've also re-seated the graphics card and still no joy.
I don't think I can try the motherboard HDMI as it doesn't have integrated graphics. Somewhere I read that the orange VGA light means a BIOS update is needed? How do I do that if I don't have any display?
I'm pretty gutted as this is all brand new gear, please can someone help me? Would be massively appreciated.
Thanks
Julian
The symptoms are:
Thanks
Julian
