[Please Help] Gigabyte Z8tx-ud3h error code 15 and hard drive not being detected
p_Bassman
133
so, for a while i have been having problems when i restart my computer, seemed like half the time when i rebooted my hard drive (a western digital blue, not my boot drive, which is a plextor px-256m5s) it wouldnt be detected... then it started to hang, the little display on my mobo saying either "0S", "D5", "DS" or "05", it would take at least half an hour to reboot, if it even rebooted, sometimes it would just turn off, also of note, sometimes i dont get a BIOS splash screen on boot, and my device manager shows an "intel(R) 8 Series/C220 Series USB EHCI #1 - 8C26" and an "intel(R) 8 Series/C220 Series USB EHCI #2 - 8C2D" with the error
"This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful."
Also, sometimes my ethernet cable just stops being detected... really annoying ?_?
my specs are as follows
OS: Win 10 basic
mobo: gigabyte z87x-ud3h
gpu: MSI GTX-770 2 gig
ram: 16 gigs G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
CPU: intel I5-4670k
Hey there, p_Bassman!
It sounds to me like you are dealing with a driver issue, rather than a hardware one. I'd recommend you to go to your motherboard manufacturer's website and search for your model. Once you find it, you should be able to see all the available downloads and drivers pack for it. Make sure everything is up-to-date from there.
Another way to do that would be to go to Device Manager and update the drivers from there. Here's something from the MS knowledge base that you might find useful: https://support.microsoft.com/en-us/kb/943104
Hope it helps you! Keep me posted! :)
SuperSoph_WD
SuperSoph_WD
