So I have ask a question on what graphics card should i get and you guy said i should get a
AMD r5 230
now my question is im trying to get a cheap graphics card that at least can run sims 3 or 4 with little to no logs I was looking at an Nvidia GForce FX5500 Graphics Card and Galaxy NVIDIA GeForce 210 1 GB DDR3 Graphics Card (fan typ
e) can i run this graphics card is my power supply strong enough cause en AMD r5 230
is just expensive for me if those graphics card i mentioned would not be compatible with my
computer cause of power suplly or other thing please tell me
Motherboard
Manufacturer To be filled by O.E.M.
Model Polaris (CPU 1)
Version CAAAAAAA
Chipset Vendor Intel
Chipset Model i865P/PE/G/i848P
Chipset Revision A2
Southbridge Vendor Intel
Southbridge Model 82801EB (ICH5)
Southbridge Revision 02
System Temperature (xx)
BIOS
Brand American Megatrends Inc.
Version 0EAS.4002
Date 7/5/2005
Voltage
CPU VCore 1.344 V
AUX 1.600 V
+3.3V 3.328 V
+5V 5.107 V
+12V 12.099 V
-12V 1.790 V
-5V 2.695 V
PCI Data
Slot AGP 4X
Slot Type AGP 4X
Slot Usage Available
Bus Width 32 bit
Slot Designation AGP
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI
Slot Type PCI
Bus Width 32 bit
CPU
Intel Pentium 4
Cores 1
Threads 2
Name Intel Pentium 4
Code Name Prescott
Package Socket 478 mPGA
Technology 90nm
Specification Intel Pentium 4 CPU 3.00GHz
Family F
Extended Family F
Model 4
Extended Model 4
Stepping 1
Revision E0
Instructions MMX, SSE, SSE2, SSE3
Virtualization Not supported
Hyperthreading Supported, Enabled
Fan Speed 3750 RPM
Bus Speed 199.5 MHz
Rated Bus Speed 798.0 MHz
Stock Core Speed 3000 MHz
Stock Bus Speed 200 MHz
Caches
L1 Data Cache Size 16 KBytes
L1 trace cache 12 KBytes
L2 Unified Cache Size 1024 KBytes
Cores
Core Speed Multiplier Bus Speed Rated Bus Speed Threads
Core 0 2992.3 MHz x 15.0 199.5 MHz 798.0 MHz APIC ID: 0, 1
current graphics card
Graphics
Monitor
Name 710S(K) on Intel 82865G Graphics Controller
Current Resolution 1024x768 pixels
Work Resolution 1024x738 pixels
State Enabled, Primary, Output devices support
Monitor Width 1024
Monitor Height 768
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer Intel
Model 82865G Graphics Controller
Device ID 8086-2572
Revision 3
Subvendor Samsung (144D)
Current Performance Level Level 0
Driver version 6.14.10.3889
Count of performance levels : 1
Level 1
AMD r5 230
Motherboard
Version CAAAAAAA
Chipset Revision A2
BIOS
Version 0EAS.4002
Date 7/5/2005
Voltage
CPU VCore 1.344 V
AUX 1.600 V
+3.3V 3.328 V
+5V 5.107 V
+12V 12.099 V
-12V 1.790 V
-5V 2.695 V
PCI Data
Slot AGP 4X
Slot Type AGP 4X
Bus Width 32 bit
Slot Number 0
Slot PCI
Slot Type PCI
Bus Width 32 bit
CPU
Intel Pentium 4
Cores 1
Threads 2
Code Name Prescott
Technology 90nm
Family F
Extended Family F
Model 4
Extended Model 4
Stepping 1
Revision E0
Fan Speed 3750 RPM
Bus Speed 199.5 MHz
Caches
Cores
Graphics
Monitor
Monitor Width 1024
Monitor Height 768
Manufacturer Intel
Device ID 8086-2572
Revision 3
Level 1
