Please help gtx 550 ti doing weird stuff
kozicki
44
well for one i got the newest nvidia graphics driver for my gtx 550 ti and for some reason the windows aero isnt working and when i open some games all the letters in the pictures will be so weird looking i cannot understand what they say and half the time im typing this i cannot see the leters because when i type the letters just glitch out then a few letters later it will let me see them :/ and if i scroll on the page IT FREAKS OUT sry its irritating me >:C
G
Guest
Guest
most likely the installation went flonky.
boot into safe mode (pressing F8)
download DRIVER FUSION (was driver sweeper).
run driver fusion to remove the 310.70 drivers ( that is what you have, right?).
reboot into safe mode.
download again the drivers from nvidia, make sure you picked the correct OS.
run the installation again.
kozicki
44
it didnt work still does the weird fidgety thing and the windows aero troubleshooter says that the gtx 550 ti doesnt support directx 9.0 and above and doesnt support pixel shader 2.0 and above.
G
Guest
Guest
i take it you didn't have these problems with the previous driver? (306.97(?))
i'd suggest going back to that, via the safe mode and driver fusion method, to see if you get back to normal.
Commandermadi
330
Did you do any driver updates? If so, roll back to older ones and see what happens. I have a GTX 550ti on one of my computers and I never experienced that though.
Also, what is the manufacturer of your card? And how long did you have it installed?
kozicki
44
ive had it installed for 1 day and the manufacturer is ASUS.
G
Guest
Guest
i see by your other post that this is a new card, my bad for not asking first. it may not be a proper working card.
gotta run for a bit, i think CommanderMadi can be of assistance. good luck!
(edit: check power connections and that it in the slot firmly - just to make sure)
