M MMM_900 Reputable Nov 22, 2014 23 0 4,510 Nov 23, 2014 #1 Can i connect my headset into my PC? im not using a sound card
Solution Gam3r01 Nov 23, 2014 By "most" I assume you mean 3.5mm, the kind found on phones. In that case, your computer should either have a port on the front, or rear (usually green on the rear) or both that you can plug it into.
Gam3r01 Titan Jan 12, 2013 25,414 974 115,440 Nov 23, 2014 #2 What interface is it? 3.5mm, 1/4", USB etc Upvote 0 Downvote
M MMM_900 Reputable Nov 22, 2014 23 0 4,510 Nov 23, 2014 #3 Gam3r01 : What interface is it? 3.5mm, 1/4", USB etc Mine does not have a usb interface. The interface is the normal one you see in most headphones and headsets Upvote 0 Downvote
M Martin9744 Honorable Aug 11, 2014 136 0 10,690 Nov 23, 2014 #4 Could you be more specific? Or tell us the name of the headset or link a picture? Upvote 0 Downvote
Gam3r01 Titan Jan 12, 2013 25,414 974 115,440 Nov 23, 2014 Solution #5 By "most" I assume you mean 3.5mm, the kind found on phones. In that case, your computer should either have a port on the front, or rear (usually green on the rear) or both that you can plug it into. Upvote 0 Downvote Solution
