Please help how to fix corrupted usb 32gb it only show 4.00mb
and i try to format it on window but window unable to format
and i also try on cmd
-diskpart
-listdisk
-select the disk i select 1
-clean
-then create partition
then this show up
here's the photo http://imgur.com/a/hAI2Y
"No usable free extent could be found. It may be that there is insufficient
free space to create a partition at the specified size and offset. Specify
different size and offset values or don't specify either to create the
maximum sized partition. It may be that the disk is partitioned using the MBR disk
partitioning format and the disk contains either 4 primary partitions, (no
more partitions may be created), or 3 primary partitions and one extended
partition, (only logical drives may be created)."
please reply thank you 🙁
-diskpart
-listdisk
-clean
then this show up
